Dear kandy
So you can't even ping a website, right?
A few suggestions and questions to try to isolate the source of the problem:
1. Are you going through a wireless Access Point connected to a wired router, or are you just using a wireless router? Please post the exact makes/models of your wireless devices.
2. When the Internet access dies, can you at least ping the IP of the router and/or Access Point, or the IPs of any of the other computers on the internal network?
3. Check your system log files to see if Windows is recording any error messages related to the connection drops in those logs:
Open the Event Viewer utility in your Administrative Tools control panel.
In the Event Viewer, look through the System and
Application logs for entries flagged as "Warning" or "Error";
double-clicking on any of those entries will open a "details" window with more information about the error/warning. If you find any entries that seem to relate to network errors, post the full and exact contents given in the detail windows.
4. To determine if the problem lies specifically with your wireless connection or with your network software in general, connect the laptop to the router via an Ethernet cable and see if you still experience the problem.
oke i have this post can help you
cropp
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
k once u log in to router u need to click on w/l settings and
Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 01 02 03 04 05 06 07 08 09 10 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
and if u want security password type any 10 digit no which u can easily remember one>and click apply do not hit generate>rate me solved if its helps102 views
