Question about Emerson EWF2703 27" TV
Emerson EWT2721 a/v cable connections won't work
The a/v connections on both the front AND rear of my Emerson EWT2721 television do not work with any dvd player I have tried, or even with a simple vcr (by a/v connections and a/v wire I refer to the red, white, and yellow connections).  The connection for the "cable wire" (the threaded connection for an antenna or a Cable television cable) was broken in a recent move, so unless I can get one of the a/v connections working (preferably the rear), I cannot use this tv ever again.
  I have tried every channel on the tv, and even went in the menu and added a channel "1", to no avail.  Nothing will show the input from the a/v wire.  I even tried two different a/v wires, and used these same a/v wires on another tv in the bedroom and a dvd player and they both worked fine, so the cables do not have the problem.
  Please help, I desperately want to save this tv, it was in perfect working order (excpet for the a/v connections) until the cable-wire connection snapped, and I don't have money for a repair shop or replacement.  Thank you in advance!
  • 1 more comment
  • Anonymous Dec 16, 2007
    av jacks do not work on the front or back.
  • stevie2222 Aug 02, 2008
    The cable/antenna connections has snapped off and I have the way of connection myn cable or antenna to the TV. What do I do?
  • jdnung Mar 01, 2009
    Same problem. Can't get the dvd/vhs player to work on my EWT2721 model. Any suggestions.
    New Friend:
How do i get to input without remote
Posted on Dec 25, 2009
You might have to press "game" on your remote, or press an input button
Posted on Dec 18, 2007
SOURCE:
How do I connect Emerson 19" model LC195EMX to direct TV
USE THE HDMI PORT WITH A HDMI CABLE FROM THE REAR OF THE DIRECT TV BOX TO HDMI PORT ON TV SET THE ON YOUR REMOTE PRESS MENU SCROLL TO THE APPROPRIATE HDMI NUMBER .OR USE VIDEO AUDIO CABLE FROM DIRECT TV BOX CONNECT TO AV CONNECTIONS ON TV SET AND DO THE SAME BY HITTING MENU SCROLL TO AV THAT SHOULD DO THE TRICK....GOOD LUCK
Oct 13, 2014 | Emerson Televison & Video
Component input won't work
There are 2 rows of RCA connectors on the back of this TV.
If you are looking at the back of the TV, on the right side you'll find the connectors.
On the bottom row, left most RCA jack is the Video in for the Component video.
on the top row, the right 2 connectors are for Audio connections.
we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
Sep 24, 2012 | Emerson LC391EM3 39 in. LCD HDTV
How can i fix emerson standard tv model # EWT2721 no sound but perfect picture
Check the audio output section circuit and speakers for fault. You must have sound knowledge in electronics to check the audio output circuits.
Jul 04, 2012 | Emerson Televison & Video
My TV is approx. 10 years old. Remote is broken. None of the codes work on the universal remote. I can't get to the external input mode to use my DVR. Help My TV is an Emerson 27" Model...
It may be a bad sensor on the T.V. and not the remote. However, if you really believe that the remote is broken,
http://www.emtcompany.com/emerson-ewt2721-remote/rc64.html
This is a link to get it.
If the channel buttons wont get you to the selected input, you probably have to play in the T.V. menu to see if you can get to the input from there, or just buy the replacement remote.
Jun 19, 2011 | Emerson Televison & Video
A friend gave us an Emerson ewf 2004A and a magnavox dvd player, to use for grandchildren' s dvds , for when they visit us. As I turn on the TV the screen reads -Helpful hints- 1. please check to see...
That is just the Setup for the TV go to this link and get the user manual really best way to program the TV also click no to the pop-up
http://tv.manualsonline.com/manuals/mfg/emerson/ewf_2004.html
Jan 23, 2011 | Emerson EWF2004 20" TV
EMERSON TV MODEL EWT2721
unplug your tv and check the volts in primary capacitor .if it will not discharge the regulator IC is bad .
Oct 10, 2008 | Televison & Video
Color are very off on my emerson EWT2721
Hey just go to menu- picture, and increase your contrast, brightness, and/or tint.
Jan 13, 2008 | Emerson EWF2703 27" TV
Emerson EWT2721 will this TV support a Sony DVD recorder?
If you do not get result you can purchase one video rf converter. Rf converter contains one videoinput in yellow colourand two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in whichplace you receive dvd signal. good luck
Sep 20, 2007 | Emerson EWF2703 27" TV
RCA RCR450 remote
here is a website that can help you https://www.rca.com/secure/service/contactrca/1,,,00.html
Apr 01, 2007 | RCA RCR450 Remote Control
Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
Jan 01, 2007 | Emerson EWF2703 27" TV
Emerson EWF2703 27" TV Logo
922 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
