Where can I purchase dtc 550 print head o Ring rubber in the uk?
I need to get spare O ring rubbers for my fargo dtc 550 print head pulley in the uk. Which retail outlet or shop can I find them in the uk?
SOURCE: Rubber/Plastic ring seal replacement
Find any parts yet? I need to replace the gasket on my Sanyo U-D22S
Posted on Aug 22, 2008
SOURCE: Kenmore KMB048 Blender
1800KENMORE
  • 6 Answers
SOURCE: fargo DTC 550 driver for windows server 2008 64 bit
Actually, Fargo drivers will not work on any 64 bit system - 32 bit only.
Posted on Apr 16, 2009
  • 1089 Answers
SOURCE: water leak between tank and main unit
Hi
If it is leaking on top of the machine and under the water tank, there is a seal that needs to be replaced. Lift off the water tank. There is a large gray doughnut cap that will pop off. Take a screw driver and slip it under the outside of the cap between the machines top and pry gently up and it will pop that side. Go to the other side and do the same. Set the cap aside and take you index finger and stick it in the center of the black gasket. Lift up and if the gasket comes out with it you need to replace it. Clean the inside of the receptacle before installing the new gasket.
Once you get the new gasket, slip it at a slight angle(flat side up), then take your finger nail and run it around the outside edge of the gasket. It will slip in, then push it down. Take the cover and snap it into place. Your good to go.
Posted on May 31, 2009
  • 4 Answers
SOURCE: Where can I find Casio Watch spare parts? My watch
replica Watches
Posted on Sep 09, 2009
Solution to head lift error problem on my Fargo printer
You don't mention which printer model you have, but we mostly see that error on old DTC5xx printers. It is usually caused when a rubber o-ring within the printer has failed (broken), and the head-lift motor no longer has the necessary connection to the head-lift mechanism.
Jul 20, 2017 | Fargo Office Equipment & Supplies
Fargo dtc 550 head voltage error
Fargo DTC550 Head Lift Error - YouTube
? 4:46
https://www.youtube.com/watch?v=1MCO3wHmLgE
Jan 8, 2015 - Uploaded by Alfonso Terrazas L
Fargo DTC550. Head Lift Error. Este error se origina porque el O-Ring que hace girar el engrane que ...
Mar 22, 2017 | Fargo Office Equipment & Supplies
Why is the harmonic balance eating into the timing cover?
On most vehicles today, the crankshaft pulley acts as the harmonic balancer. It also has the grooved outer ring that the serpentine belt rides on. Between the central hub of the balancer and the outer ring is a strip of rubber that the outer ring is pressed onto. This rubber, over time, ages and shrinks. This allow the outer ring to walk inward (or outward) of the centerline of the pulley. This causes the serpentine belt to wear out prematurely and can cause the problem you describe. You need a new harmonic balancer. It comes complete with the rubber and outer ring already attached. Check your belt at the same time to see if it needs replaced as well.
Oct 22, 2015 | Cars & Trucks
Can i replace focusing ring on nikon 18-200 lens
Rubber focus ring can be purchased in ebay.
The rubber ring may be attached to the lens with glue. Use denature alchohol between the rubber and lens to remove the rubber ring. It can be stretched little. Once removed, clean any glue on the lens and stretch the new rubber ring and install.
Nov 01, 2012 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Well can some one shwo me how to chage the O" ring
i send you the manual for help,i send you from mail.
Mar 03, 2011 | Fargo DTC550 Thermal Card Printer
Screen reading wrong ribbon - had the same ribbon in it since the last printing.
My DTC300 printer has the same problem.
The ribbon supply roller is driven by a small motor connected via an O-ring belt. The printer rolls the ribbon back and forth to locate the start of each color panel on the ribbon during printing and ribbon detection. Without the O-ring, the ribbon only moves toward the take-up spool, eventually going slack so that the color detector only sees one color - hence the "wrong ribbon" message. In my printer, the slack ribbon also gets chewed up in the print head.
You can order a whole belt kit (~ $20 + shipping) or you can locate a generic O-ring belt (1.8mm x 26mm).
Cheers
Sep 27, 2010 | Fargo DTC-300 Thermal Card Printer
I need a rubber ring for the door, where can I get one from in Ireland.? This is a Whirlpool front loading 9kg washing machine. As the machine works very hard and the ring gets pierced a bit too easily I...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
mcminone.com
Or google whirlpool spares ireland.
Feb 06, 2010 | Whirlpool AWM9000 Front Load Washer
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Fargo DTC 550 driver for windows server 2008 64 bit
Mar 21, 2009 | Fargo DTC550 Thermal Card Printer
My DTC 400 bladge printer jams a lot.
The DTC400 has an o ring that drives the card feed rollers. Fargo has had a problem on older DTC400 printers with the o ring stretched or broke. This causes irregular feed roller issues, ribbon breakage or misalignment of print registration.
It is recommended to do a ribbon sensor calibration. This can be done through your print driver using the directions in this link.
Your DTC400 came with a two year manufacturer warranty. Contact Fargo Technical Support at 800-459-5636.
For more information about id card printer systems, visit our website at www.safecardid.com
Nov 13, 2008 | Fargo Office Equipment & Supplies
134 people viewed this question
jasbo
jasbo
