Question about Lectrosonics FENDER PD-250 PASSPORT SYSTEM + 1 SHURE HANDHELD&1 LAVALIER WIRELESS SYSTEM / Microphone
Whenever we switch it on it immediately goes into Protect Mode
Whenever we flip the switch to On. The Light goes from Green to Red. From Power to Protect. How do i fix this issue... I've had my Fender PA for 2 to 3 years now and i've never had this issue.
  • Michial Gueffroy May 11, 2010
    Have you checked your speaker cables to see if there is a dead short?
2 Suggested Answers
  • 3 Answers
SOURCE: i have fender passport pd-250
One or more of the power transistors are shorted. There are eight transistors in the amplifier section - 2 high & 2 low for each channel. This unit is difficult to open up to work on.
Unplug unit and check speakers with a multimeter to make sure they are not shorted.
Take off front panel (8 screws).
Remove power supply shield with yellow tape (2 screws).
Remove 2 screws holding top of power supply, loosen bottom screws.
Replace front and hold in place with a couple screws.
Turn unit around.
Remove screws holding heatsink (6 screws)
Open rear storage door.
Carefully pull amp section out, being careful of tightly routed wires. Note any connectors you disconnect.
The amplifier is the board on the top, the power supply is in the silver box.
Push the power supply forward and loose the black screws holding the amplifier board bracket closest to the heatsink.
Loosen the top brass screws holding bracket to heatsink and remove the bottom screws.
Remove all eight of the screws holding the transistor brackets & transistors to the heatsink. Look and take careful note of how the plastic insulators weave through the transistors. If you get this wrong, you can short out the whole amplifier when you turn it on.
Slide the amplifier board down and out where you can get to the bottom. Note the wires and connectors going to the small protect board over the amplifier.
Check the transistors with a multimeter to find the shorted ones. Remove and replace bad transistors. These are connected in pairs.
Reassemble in reverse. Be careful of reconnecting wires and insulators. Don't test until the amplifier PCB is back in place and you're sure of all wires. If the PCB is touching the power supply, you'll short it out.
Good luck, I told you this wouldn't be easy!
Posted on Jun 09, 2011
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Apr 05, 2010 | Sony BRAVIA KDL-40V3000 Television
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
May 29, 2009 | Pyramid PB1217X Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
686 people viewed this question
Top Lectrosonics Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Lectrosonics Audio Player and Recorder Expert? Answer questions, earn points and help others
