Question about Polaroid FLM-3201 Television
Polaroid FLM-3201 power light comes on. no picture or sound. is there a reset or fuse?
Where can i find these and i replaced it with one and plugged it up the fuse didnt burn but the set also did not come on could it be the power supply?
Posted on Jan 21, 2008
Check the fuse near power supply.
Cost to replace about $35.00
Posted on Oct 18, 2007
SOURCE:
Poloraid hdtv 36 inch model FLM 3201 PICTURE
FAULTY POWER SUPPLY OR INVERTER PANEL ON BACK OF SCREEN
AVERAGE REPAIR COST £60 TO £80+
Aug 25, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
FLM-3201 will not turn on
You can download service manual here:
http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look for bad capacitors, burnt parts in the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Oct 05, 2009 | Polaroid FLM-3201 Television
Picture takes almost an hour to come on
Replace swollen capacitors on power board.
Aug 29, 2009 | Polaroid FLM-3201 Television
Flm-3201
Sounds like the back light is out, and the unit needs servicing. You can check this by shining a flashlight close to the surface, and if some image is seen, the the back light is the cause. Else the LCD driver is gone.
Aug 03, 2008 | Polaroid FLM-3201 Television
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
Nov 24, 2007 | Polaroid FLM-3201 Television
No picture Just Sound
Hi
There are different possibilities in your case¸but what happened to me ...
The LCD Backligh is out , I mean the bulbs or neons of the screen BACKLIGH, you have to check either the lights itself or the driver circuit which supply the HV to operate it, usually its a separate small long PCB beside the TV main board .
You can try this trick , Keep all lights off in the room and bring a table lamp, preferred a white neon one and face it lighted on the top of the screen with the TV on , try watch a very dark but exact picture with the sound you are hearing. This is a way to be sure that it is LCD backlights problem when using an external light to illuminate the screen .
It worked for me ,Good luck
Nov 10, 2007 | Polaroid FLM-3201 Television
Polaroid FLM-3201 Television Logo
238 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
