Question about Kenmore HE2 Plus Front Load Washer
No manual ...no power- how do I work this machine? I'm able to lock/unlock it
Don't have manual for my new kenmore front load HE2 plus washer- no power when I press the power button. Can you help
  • 460 Answers
THIS IS THE ONLY THING YOU CAN DO
Check that the unit is plugged into a working outlet and for
blown fuses.
This must be done by a THECHNICIAN SPETIALIST
Unplug washer or disconnect power.
Check continuity of line cord and line fi lter.
Check harness connections to CCU.
Plug in washer or reconnect power.
Check the touch-pad/LED assembly by selecting different
cycles and changing the modifi ers and options available to
confi rm the touch-pad/LED is responding.
Unplug the harness to UI and check with a DVM or VOM on
Connector UIP3 if correct voltage is present.
Pin 1: -5V
Pin 2: 0V (connection to Line or neutral is present in
normal operation).
Pin 3: -12V
If voltage not present and CCU is powered correctly (line
cord and linefi lter has continuity) the CCU is broken.
Disassemble the UI and check harness to UI and
Interconnection on UI between Center and Right Board.
Was this helpful?
Posted on May 12, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine will not turn on it shut off
Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
Front door is locked and I can't get it open
Hello shoya_garris,
There is a manual release tab you can use to open the door. Make sure you unplug it first. Remove the bottom front service panel. Carefully reach up and pull the manual release tab on the bottom of the door lock assembly until you hear it click. Wear some gloves there can be sharp edges on the inside of the machine panels. Hope this helps.
Thanks,
edgin96
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
356 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
