Question about Nintendo DS Lite Console
My ds is broken. I put the car charger in the charging slot. I put it there and it would not come out. Somebody pulled it out for me but they ripped the little metal sticks in the ds charging slot out. now it will not charge so now i cannot play with the ds. can u help me?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
Sincerelly if you are not technician inclined, the cheapest and cost effective option for you is to buy an external battery charger for your NDSL like the one in this link (just as example, not the cheapest option or like I'll get money for that).
http://www.daydeal.com/product.php?productid=13128&cat=2139
The second option is to pay a technician for the repair. Not the one you would like as you are finding answers here.
Now the technician option, this problem need a replacement jack and some technician soldering skills, not too difficult but you will need some expertise and tools like a small thomson 3 windings screwdriver, philips and blade precision screwdrivers, a 15 watts pencil soldering iron and maybe some pliers to take out the broken jack and put a new mini USB, Surface Mounting Device jack in place being careful not to provoque a short circuit caused by bad solders (may need a cheap DMM to test continuity also).
You need to be very careful as you only need to ge out the battery and open the bottom part of your DS, disconect the top LCD flexible lifting the brown lock, and the other two coax wires pulling em up to have access to the PCB securelly without damaging anything else. You can find some videos of dissasembling the NDSL over the net.
After opening it just neet to take the bad part and solder the replacement, connect all and close the unit, testing it before you put the screws.
Good Luck...
Posted on Oct 12, 2007
  • Ed Perez
    Ed Perez Oct 14, 2007
    I need to appologize for a mistake I did about the NDSL charger jack as I described it as a mini USB jack though it is bigger and different shape so, to replace it, would be more difficult as you must find a special nintendo DS lite replacement jack. The mini USB one was difficult to findalso but at least you can take it from a broken camera or other cheap charger device, though I have no idea where to find the nintendo one.
    BTW: if too difficult to find the item, anyone can have a last resort of replacing the jack and the charger plug for a more common model.
Ds lite charger slot is broken
These are common problems with Nintendo DS Lite systems, but the good news is that almost anyone can fix them on their own.
Nintendo Repair Shop
www.nintendorepairshop.com
Dec 31, 2011 | Nintendo DS Lite Console
My nintendo ds xl would not turn on and it would not charge the charger i not broken an the ds is not.
Check the flex connector between the bottom and top half. Check all connectors and make sure they are not loose. If it isn't a problem with one of those, you have a problem with the LCD screen. These go out all the time on DS systems. You either have to send it in, buy a new DS, or look for replacement parts on Ebay. New screens can be extremely fragile so be careful. When installing, make sure that the large end of the cable, the one with the contacts, goes through the slot cut out for it. Gently pull it through. Warning, the metal collar can be frustrating.
Aug 25, 2011 | Nintendo DSi XL Burgundy
My ds lite turns on but it will not charge. It's not the battery or the charger. I have tested the fuses with a multimeter and both fuses read 0 ohms. The orange charge light does not flash briefly when I...
You can try buying another battery, or by buying a charging station that could just charge your battery (incase its the charger port on the ds thats broken).
Feb 28, 2011 | Nintendo DS Lite Console
The ds lite doesn't charge any more i changed the battery still doesn't charge.i had this problem with 2 previous ds lite.
dude the charger is broken,if not test the voltage as your charger might be getiing less or more electricty
Nov 19, 2009 | Nintendo DS Lite Console
Charge a DS lite without DS charger
turn your ds lite on, then realy quickly close the lid
Jul 20, 2009 | Nintendo DS Lite Console
Nintendo ds lite won't charge just the red light to say battery is low my nintendo ds lite wont charge it always says its red
Did you attatchthe charge cord into the back of the Ds and attatch it to the wall? If you did and it didnt work, then I suggest getting it looked at, as this is usually the less expensive way of fixing it.
Mar 13, 2009 | Nintendo DS Lite Console
Charger socket broken
That little black thing goes into the charger so without it, or something to replace it, you can not charge, unless you somehow found a way to take out the battery and charge it outside of the ds. I would highly recommend sending it back to Nintendo or something like that.
Jan 24, 2009 | Nintendo DS Console
Nintendo ds problem
it may be a technical difficulty in the gba slot try bowing in it or get a q tip and kinda dust it out or blow in the game becuse the game isint making any connections to the ds and with the charger thing if u push in the charger too hard you might mess up the reciving thing inside the ds so it wont get the charge so be very careful when it comes to ds.....if u have any more questions plz let me know
Oct 25, 2008 | Nintendo DS Lite Console
Cant get the re-charging wire out
wiggle the charger gently backwards and forwards. Make sure you are using the right slot and the right wire. There is a big one for the DS, and a smaller one for the DS Lite.
Dec 12, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
127 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
