Question about IBM ThinkPad T30 2366 Notebook
Power button won't work
I shut down properly, and later when I went to start it back up, the power button seemed to not work.
I removed keyboard tray, cleaned and inspected and replaced.
Once with battery only, it seemed to get power but not thru to boot cycle
it would go over to the circled z light only (hibernate?) and with or without ac power, it seems not to get power? Green battery light when plugged in
battery should still be good, I get 2 + hrs usually -
I bought a second hand docking station (for the power button) and hoped it would re-route the power instead of through keyboard control - no love
any suggestions out there?
  • 2,404 Answers
Hook up the ac adapter only and see if you just get power that way. If you do then you know the battery is faulty cause that would cause the power button to act like its shorted out.
If you hook up the ac adapter and the power button still isn't acting quite right then its either going to be a problem with the power control board or the motherboard.
Posted on Jul 12, 2009
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
Mar 04, 2012 | Toshiba Satellite C650 series C655S9520D
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
My laptop was just working i shut it down and went to turn it back on a hour later and i get nothing no noise, light, or any sort of indecation that there is any power. I tryed removing the battery and...
Holding down the power button as you did, is only helpful in clearing CMOS. This does not seem to be your issue. The battery itself is the most likely culprit, power cord or not- it will not work without a good battery. Start with that as your troubleshooting procedure.
Jan 09, 2018 | Acer AL2017 20" LCD Monitor
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Will not power on
Pl. check th ebattery status.
May 09, 2009 | IBM ThinkPad T30 2366 Notebook
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
IBM ThinkPad T30 2366 Notebook Logo
381 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
