My Kenmore Elite Catalyst (#110-24042301) will fill, but won't spin or empty. When I turn it on there is a burning smell - not rubber - more like electrical. What could it be?
  • 6 more comments
  • itsaboutt786 May 09, 2009
    No, it won't do anything at this point except fill
  • itsaboutt786 May 10, 2009
    I will take the cabinet off this morning. Am having a hard time getting it off. Something seems to be holding it. Maybe I need to remove some hoses first. They are attached to the cabinet and then to the top of the tub.
    What will a bad motor look like? Any chance it could be the coupling?
  • itsaboutt786 May 16, 2009
    Got the back off. How would I tell if the motor is burned out? No it does not agitate.
    can't turn it on. It's all apart now! I checked the pump. wasn't clogged. I've narrowed it down to a motor.
    Thanks
  • Samuel Charles Spriggs May 11, 2010
    Turn it on (where it would be agitating) for a few seconds while you watch it, but don't put your hands inside the back anywhere. Just watch and see if anything moves or crackles or appears to get hot. (Unplug quickly if you see something.)
    Then, after about 10 seconds, whether you see anything or not, unplulg machine. Touch motor, with machine unplugged, to see if it's warm/hot. Let me know.
    If this washer is direct drive (not belt driven) it will have a coupling. In that case, yes, it could be the coupling.
    Have you found anything yet?
    Well it sounds like your motor has burned out. Can you remove the back to take a look?
    Does it agitate?
    President:
  • 1,489 Answers
Okay, great!!
Posted on May 16, 2009
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
My coolant was empty, they filled it , now I have this burning rubber smell
your brake caliber is hanging up not releaseing you'll have to replace the caliber and then bleed the brakes.have a nice day.
Sep 22, 2012 | 2003 Dodge Caravan
Kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
Aug 02, 2010 | Kenmore Elite HE4 Electric Dryer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Not spinning as well
From what information I could find without having a model #, This unit does NOT have a belt. Instead there is a coupling that contains some rubber that connects the motor to the gearbox. Requires a service technician to replace.
Nov 29, 2008 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite top loader washing machine is not spinning well
USUALLY ITS A BROKEN COUPLER TOP 15 YRS AND NEWER DO NOT HAVE BELTS
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
178 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
