Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My Kenmore 90's series washing machine will not move into the spin and rinse cycle unless we use a screwdriver to put pressure on the switch. Does this mean the switch is bad? The spin cycle or draining will not start at all now. I used to be able to hold it down with a screw driver but that won't work know either. I really don't know what needs done to get it going again. Any suggestions are welcome!
  • 3 more comments
  • Soonji May 10, 2009
    to scsprigss-yes
    It was loose, I tightened it. I still have the same problem. I belief I just have to replace the lid switch
    Originally it worked as it should, close lid and it works
    Then it worked only if you banged the lid (jarring what I now know as the lid switch)
    Finally, it does not work whatsoever, I must assume I need to replace the lid switch, that being that case, how do I go about doing that?
    I'll try that out when I get my part, thanks
  • Samuel Charles Spriggs May 11, 2010
    The switch is probably still good unelss pressing on it has damged it (not that it would necessarily).
    It sounds like the switch is loose in its mount -- can you check that -- can you move it around a lot?
    The switch: is it the one the lid/door presses when it closes?
    President:
  • 1,489 Answers
I looked at a picture of the machine. It appears that the top of the washer pops up by inserting a large flat tip screwdriver into the seam between the top and the bottom of the cabinet and prying upward. Do this on each front corner, the lid should come up.
Raise the lid and you'll see how to remove the lid switch. It has a connector on it which pulls off. Put in new switch, put on connector.
Posted on May 10, 2009
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series top load washer: won't agitate or spin
Sorry to give you bad news but this sounds too much like the transmission is shot. It's a bit of work to change and probably some luck to find one at a reasonable price, so my advice is to ditch this machine and get another. :(
Joe
Oct 01, 2009 | Kenmore 24032\24036 Top Load Washer
The timer you have has a bunch of small gears inside. The case is made of plastic. Yes the timer is most likely shot.To get the timer off you grab the black plastic rod in back out and this releases the knob. Then you can access the screws holding the timer on.ec1c7f4.jpg
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
Water wont leave the machine in rinse or spin cycle
Sounds like you have a broken lid switch, most likely part # 3949247,,#11 on diagram. Dave www.washermd.com
Dec 08, 2008 | Kenmore 22422 Top Load Washer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
305 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
