Question about IBM ThinkPad T30 2366 Notebook
Will not power on
Help
i shut down normally, and later when trying to start up, power button doen't respond.
I have docking port also - tried to start it thru it and still no love...........
i removed keyboard tray, cleaned and inspected, and once with battery only, it wanted to start, but again, no love - any hints as to how to "jump start" it?
  • 3 Answers
Pl. check th ebattery status.
Posted on May 21, 2009
My apple laptops login screen keeps going on and off on and off i cant login
Try resetting the SMC
Before Resetting the SMC Try each of the following steps in this order before you reset the SMC. Test the issue after completing each troubleshooting step to determine if the issue still occurs.
  1. Press Command + Option + Escape to force quit any application that is not responding.
  2. Put your Mac to sleep by choosing the Apple () menu from the upper-left menu bar and then choosing Sleep. Wake the computer after it has gone to sleep.
  3. Restart your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Restart.
  4. Shut down your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Shut Down.
If your Mac appears to be running normally but isn't responding, force the computer to shut down by pressing and holding the power button for 10 seconds. Note: You will lose any unsaved work in any open applications.
For Mac portables experiencing issues related to the MagSafe power adapter and/or battery, try:
  1. Unplug the MagSafe power adapter from the Mac and the wall power socket for several seconds.
  2. Shutdown the Mac. Physically remove and re-insert the battery (if it's removable) and startup the Mac.
If the issue is still not resolved after following the troubleshooting items above, an SMC reset may be necessary.
After performing normal troubleshooting, these symptoms may indicate that an SMC reset may be necessary:
Fans
The computer's fans run at high speed although the computer is not experiencing heavy usage and is properly ventilated.
Lights
The keyboard backlight appears to behave incorrectly (on Mac computers that have this feature).
The Status Indicator Light (SIL) appears to behave incorrectly (on Mac computers that have an SIL).
Battery indicator lights, if present, appear to behave incorrectly (on portables that use non-removable batteries).
The display backlight doesn't respond correctly to ambient light changes on Mac computers that have this feature.
Power
The computer doesn't respond to the power button when pressed.
A portable Mac doesn't appear to respond properly when you close or open the lid.
The computer sleeps or shuts down unexpectedly.
The battery does not appear to be charging properly.
The MagSafe power adaptor LED doesn't appear to indicate the correct activity.
System Performance
The computer is running unusually slowly although it is not experiencing abnormally high CPU utilization.
Application icons may "bounce" in the Dock for an extended amount of time when launched.
Applications may not function correctly or may stop responding after being opened.
Video
A computer that supports target display mode does not switch into or out of target display mode as expected.
A computer that supports target display mode switches into or out of target display mode at unexpected times.
Oct 20, 2013 | Computers & Internet
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
1) difficult connecting to yahoo, computer slow
sounds like virus or spyware at first. get microsoft security essentials and scan you PC i bet it's riddled
the PC should power off if you hold the power button in for 4-6 seconds, rather than use the switch at the wall
Jan 13, 2010 | Computers & Internet
Screen not responding to any touch
After cleaning my screen from my kids sticky fingers and having it outside in the cold .. around zero my screen stopped working. The screen displayed okay but the calibration was so far off I could use it. I played with it for a while until I got it to work again.. First I recharged it. Then tried to just do a shut down which didn't work cause you have to hit the yes on the screen. Then I tried the reset button, then tried the reset and holding the power button then plugged it in the usb port. Did a shut down, it reassessed life and started working again. Better than when I bought it.. from Kijiji.
Dec 24, 2009 | HTC Touch P3452 Smartphone
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
When i try to shut down my computer it does not shut doen but it gets restart every time
What version of windows are you running? Also, when did this problem start and how old is your PC?
On 2000/XP: On your start menu click on Run and type the following command: SHUTDOWN -s -t 01
This will shut down windows, and then you can safely turn off your computer. You may have to hold the power button for 10 seconds before it turns off.
NOTE: This is not a fix, just a temporary solution.
Oct 02, 2008 | Computers & Internet
Please Help !
If your Zen V wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Jan 28, 2008 | Creative Labs ZEN V Plus MP3 Player
IBM ThinkPad T30 2366 Notebook Logo
139 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
