Question about Dometic NDR 1292 Refrigerator
Dewinterized 5th wheel. Turned on Refrigerator.
Dewinterized 5th wheel. Turned on Refrigerator. Doesn't run on AC or gas. Lights on panel are on but refrigerator doesn't start to run. Our refrigerator is a NDR 1492 that is in our 2003 Teton.
  • 906 Answers
Good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
I have an Innsbruck 5th wheel, my refrigerator won't run
check back see if chimney is hot on electric or LP see if lit if hot unplug the thermistor from the back board let run if gets cold replace if not bad board or cooling unit
Jul 07, 2014 | Dometic RM2652 Refrigerator
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
1992 Sierra 5th wheel fridge not working
Hi your frige works with heat applied to the coil at the rear of the unit.
the first thing to know is the when turned on at the control panel if running in gas or electric you must feel a heated area on the rear of the unit (access from the outside access panel) the vertical cylinder at the right rear (after some time a half hour or more) should be hot to touch, if not. go on line and look up-camper refrigerator troubleshooting. and follow the questions. remembering the controls need to have 12 volts to operate in any mode and 120 volts to operate in the electric mode and lp to operate in gas mode
May 23, 2014 | Cars & Trucks
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
NDR 1292 - Was freezing/cooling on electric, but stopped freezingcooling, tried gas but doesn't freeze or cool
Since it does not work on either AC or gas - do you have DC to the unit? I have spent many hours troubleshooting a Dometic that turned out to be a corroded DC connection.
Jul 26, 2011 | Dometic NDR 1292 Refrigerator
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
Refrigerator was on AC and stopped working
some times turning them does work . / and taking them for a ride in a pick up truck . and when you get it the shop / and they tell you there nothing wrong with it . .. the ride did it .. try it / it may work. and if not then repl. **** ..
Jan 16, 2010 | Dometic RM2852 Refrigerator
2007 Dodge 2500 Mega Cab No Heat, AC, Defroster, Vent fan
possible faulty heater resistor block or control head
May 09, 2009 | Dodge Ram 2500 Cars & Trucks
Unit will not turn onto AC
Heating element is burned out
Oct 20, 2008 | Dometic NDR 1292 Refrigerator
Dometic NDR 1292 Refrigerator Logo
186 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
