Question about Ryobi Cultivator
Gasoline/Oil Mixture i lost the manual for my ryobi rototiller and i dont remember what the gasoline/oil ratio was, can you help me?
  • Anonymous May 19, 2009
    Need to know gas and oil mixture. Ryobi should have included the blend formula on the gas tank or on a label
It is 32-1 I just got one from a friend to use for a few days.
Posted on May 18, 2009
    President:
  • 2,692 Answers
I would not run it any any less that  50/1 ratio.
Posted on May 09, 2009
My Ryobi 410r need 1: 32 ratio for oil and gas ratio
Posted on May 24, 2009
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What is the gas/oil ratio mixture?
16 to one which is one pint oil to one gallon of gasoline.
Sep 29, 2014 | Homelite Pump Model: Xls 2-1 Parts Manual
Mix oil and gasoline
Hi royandruha...
Use two cycle oil and fresh gasoline.
Normal mixture of oil to gas ratio is 50 to 1
Use 1 pint of two cycle oil to 6 gallons of gasoline...50 to one mix
Please take time to rate me
Bud
Oct 11, 2012 | Garden
I want to confirm the ratio of fuel (unleaded petrol) to oil mixture for my Ryobi chain saw, model CS3816. Is it 50:1? What oil do I use?
Hi afs3...
Yes use the 50:1 oil to gas ration. 1 pint of 2 cycle oil to 6 gallons of gasoline.
Sep 04, 2011 | Garden
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
What is the mixture of gas to oil for the Ryobi SS30?
Hi planeta6...
50:1 will be the mixture of gasoline to oil..
One pint of two cycle oil to 6 gallons of gasoline
Aug 14, 2011 | Ryobi Garden
Have lost instuction manual. Need to know oil/gas mixture for leave blower Model RY09550
Your Ryobi should take a 50:1 mixture. In the USA, that is 2.6 ounces of 2 cycle oil per gallon of gasoline. I strongly recommend to buy 2 cycle mix that has fuel stabilizer in it. It would come in a 3.2 ounce bottle and mix 1 bottle per gallon.
Sep 22, 2010 | Garden
How do I change one gallon of a 50:1 gasoline mixture to 40:1?
  • 40:1(gasoline:oil) ratio requires 3 ounces of oil.
  • 50:1(gasoline:oil) ratio requires 2.6 ounces of oil.
  • So for you to change to 40:1 you need to add .6 ounces of oil
    Apr 01, 2010 | Garden
    Ryobi Cultivator Logo
    831 people viewed this question
    Top Ryobi Garden Experts
    Nick Olsen
    Rexter1
    Roland W VanLue
    Roland W VanLue
    Are you a Ryobi Garden Expert? Answer questions, earn points and help others
