Question about ASUS Eee PC 1000H Laptop
Caps on/off indicator
The "caps on/off" indicator (yellow box) don't work....
Caps lock indicator not working easynote
You should go to service to check if the led is still ok or needs to be changed.
Apr 15, 2013 | Packard Bell EasyNote E2 316 Notebook
2005 honda accord yellow light came on after fueling
Lets review - - yes if the warning light is on because of the gas cap and that problem has been taken care of, the light may go off on its own in time. Or not.
If the warning light is on because of something else, I doubt the engine is in danger of blowing up. The light is on because the computer has found something that will affect performance or emissions. It is a method to tell the driver not to drive the car and pollute the air.
So yes take it to an auto parts store and get it scanned. They can tell you what the codes are and then turn the light off. Depending on the codes, the light may come back on.
Dec 20, 2012 | 2005 Honda Accord
Jandy Legagy LRZ pool spa heater not Igniting at all?
F4 = bad igniter ... Has this heater worked in the past and just suddenly stopped? Look for a bad igniter.
Nov 25, 2012 | Pool & Spa
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
Why would my truck's fuel cap indicator be on?
that code usally is the oxygen sensor not the fuel cap
Apr 24, 2012 | 2004 Chevrolet Colorado
RUUD Achiever 3 ton roof unit. Pops fuses. Place "hard" fuses in and it would pop the house's 60A fuse. Checked both motors and they spin just fine at the touch. Both caps also...
The compressor is going bad or the unit is charged wrong...
Whatever the cause the problem is the compressor locking up and blowing the fuses...
Clean the condenser coil...maybe the pressures are going too high...
If that don't work, then the compressor is shot or over charged...
Here is a tip that I wrote about how to clean your condenser
Cleaning Air ConditionerCondenser Coil with Pictures
heatman101
Jul 25, 2011 | Ruud UBHC Air Conditioner
Please help. The 789uiopjkl;m./ keys have keypad numerals on the front bevel. when I try to type "uio" for example I get "456" and "jkl" gives me "123". To get the...
The number lock feature is enabled. You should see an indicator for the Num Lock (lit when on) that is next to the Caps Lock indicator.
You should be able to disable the lock by pressing Fn and Num Lock together on the keyboard. (On some Sony Vaio keyboards, type CTRL+ALT+NumLock or Shift+NumLock.) The number lock should be at the top of the keyboard near the F1-F12 keys. Sometimes the key is shared with the Scroll Lock function (otherwise it will be nearby). It's really easy for the Number lock to be enabled on some Sony keyboards; just some dirt between the keys can enable it when you didn't turn it on intentionally.
I hope this helps.
(I don't have the VGP-WKB1 wireless Sony keyboard and can't find a good picture of it to find the Num Lock key for this model.)
Jul 08, 2011 | Sony VAIO VGP-WKB1 Keyboard
I am getting this "( O )" indicator lamp on my
It's an yellow warning indicator lamp. It lights when brake pads are weared. Now it's time to replace the used brake pads!
Mar 09, 2011 | 2005 Audi A4
Kodak EasyShare C643 Digital Camera won't take picture
take your battery out for 5 mts then try it again
"Was this helpful?"
Apr 02, 2009 | Kodak EasyShare C643 Digital Camera
ASUS Eee PC 1000H Laptop Logo
333 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
