Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My bike was runing good it,s a94 fatboy the other
My bike was runing good it,s a94 fatboy the other day the taile light quit work,n and then one of my drive,n lights burt out put new one in so i go to go for a ride and don,t go 5 mil and the bike backfires and shuts down no fire bike turns over no fire plus now my high beam is burnt out is there fuse block on my bike or what causeing no fire thanks joe
  • Anonymous May 15, 2009
    94 fatboy had no fire moved some wires the bike backfires not even on so i said i have power now so i tryed it it started but don,t sound the same. took it down the road it,s holding back the kicks right in and sound fine rev high and hard to start. seems to want to start win i let off the start button on kick back the wires i moved was down by starter and i taped the braker on the rear fender so i don,t no.my battire was dead so i look in it and the cells were empty so i put water out of tape in it thay tell me now i was,t to do that could the battire shorted out in side and did something to my bike.could my bike jumped it,s time it run,s now when i boost it but don,t sound good. the bike,s chargeing
  • huff455 May 23, 2009
    Same rough on idle and won't take throttle.Last time the bike did this I change the plugs and wires and then it ran fine.Now after one ride its missing again.Tried another module and coil but its still not running right.Guess I'll try the voltage regulator next.Gonna rename the bike Fantam I guess.
Sounds like your voltage regulator is bad or come unplugged
Posted on May 15, 2009
My 2002harley davidson Fatboy/soft tail is stuck in 5th gear
Hi Anonymous, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck.
Harley Davidson Manuals Mark Workshop
Dec 23, 2013 | 1993 Harley Davidson XLH Sportster 883
2010 Harley Davidson FLSTF Softail Fat Boy tail light not working
Hi, Laynebk tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Tail lights and brake light issues
http://proudfewmc.net/SiteAssets/99483-11.pdf service manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2010-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Oct 24, 2012 | 2010 Harley Davidson FLSTF Softail Fat Boy
How to remove a tail light assembly on harley fatboy 2006
Apr 29, 2012 | 2006 Harley Davidson FLSTFI Fat Boy
I'm replacing a tail light assembly and wiring
Usually it connects under the seat somewhere and the wires run under the fender in a trough.
good luck
Steve
Jul 19, 2011 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Fob on 2004 fatboy
The FOB is a security device that will help protect your bike. If it is far enough away (i think 20 feet) your bike will not start, Without the FOB the fuel pump will not run and the lights will flash on and off. When you come back to the bike with the FOB the bike will run normaly. So do not leave it with the bike unless you want it gone when you come back.
Jun 14, 2009 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Problem with the signal lights on my 2002 Harley Fatboy
Can you check if the bulb is busted? Most likely your tail light bulb is fused.
May 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Tail light problem
look at all wiring, weather can make the skin of a wire become brittle, 2 or more wires can be touching one another
Feb 23, 2009 | 1986 Dodge Aries 4 Door
2007 Harley Fatboy Taillight problem.
Check to make sure BOTH light filaments are intact. Or try another bulb to double check the situation before wasting to much time on a simple fix.
May 29, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
238 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
