Question about Refrigerators
Want to reverse door handles
I am reversing the door on my old Kenmore refrigerator. How do I get the door handles off so they can be moved to the other side. One of the fastners for each handle is "hidden", with no apparent way to get the handle unscrewed. The other end on each handle wraps around the edge of the door so can be easily be unscrewed.
    President:
  • 2,692 Answers
On most you take the top hindge off. Lift the door off the bottom one then remove the bottom hindge.
Posted on May 09, 2009
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
How do you reverse the door on a kenmore cold spot 106?
Take door off, reverse the handle and hinges to other side of door and reinstall.
Mar 04, 2016 | Kenmore Refrigerators
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
Can I reverse the door on a kenmore 253.6580250A
Remove doors starting from the top, reverse handles, and hinges starting from the bottom. Owners manual should show you how
Mar 04, 2014 | Kenmore Refrigerators
Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
Aug 07, 2009 | Refrigerators
Removing refrigerator door handles
You might try checking to see if the screw head is actually on the handle, but hidden by the handles cover. Look at the side and see if you notice a seam. This can be pried open and the screw head will be seen.
Feb 23, 2009 | Kenmore Refrigerators
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Switching doors to open the opposite direction
Look on the other side of the door and see if there's a plug covering a hole even with where the door handle attaches on the opposite side. If so, I think you just unscrew the handle from the top of the fridge door or bottom of the freezer door an unhook the other end and reattach on the other side of the door. And unscrew and move the hinge to the opposite side. If your doors can be reversed the holes should arleady be in place. It didn't look overly difficult when the delivery guy changed mine when the fridge was delivered.
Nov 24, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
414 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
