Question about Hitachi CMP205SXU 25 in. Plasma Television
No Display I have Hitachi CMP205SXU 25 in. plasma monitor, with 13w3 type video input terminal. I connected the my DELL precision 470 to it through 13w3 Hitachi 4119 adapter and HD15 SVGA cable - no sync signal - no signal at all.What is the problem?
  • APPLEROAD Dec 08, 2007
    Hi, did you ever solve the problem with Hitachi CMP205SXU. I also have this monitor and would like to know if you got the adapter to work. The 13W3 to HD15........Thanks
Hi there goran if your still watching this post... I have the same problem and i have a feeling it has to do with the pinout of the adapter we are using... the 13W3 connection does not have a standard pinout, so you need to find the right adapter... if you have any leads or new info i would love to know too!! edwardrytas... u can find me at hotmail... cheers.
Posted on Oct 16, 2007
  • 661 Answers
For the HD15 connection you need to set your TV to PC mode
the only thing I can think that you may be doing wrong is that you need to "ACTIVATE" the external outputs on the laptop,as they are not on by default.
To switch video output mode  LCD / CRT (monitor/PC mode) /TV mode plus some dual modes LCD + CRT / LCD + TV
I have found that the overlays used for video playback do not work in the dual modes,  (and I have found that CRT monitor mode is best for connecting to a large TV)
so switch your TV to PC input,  connect your HD15 cable and SWITCH output mode on your laptop (usually Fn F5) press until you get an output,
you will also need to connect audio, so get a phono -> 3.5mm jack plug and plug that in also, and you are ready to rock and roll
Posted on Oct 11, 2007
I have a Hitachi 55hdt51M 55" plasma monitor/TV with no AVC75 controller. Can I operate this monitor/TV without a controller box vias some sort of direct hookup? The only input connection is labeled "in...
You can use either input to use the monitor as long as you have the correct cable. HD15 to DVI can be converted and so can HDMI to DVI. Only hold up is the type of DVI. There are three types and I cannot remember for sure the designation but I believe there is an I, S and a D. The device will have to be able to display in a matching format.
Jan 27, 2014 | Televison & Video
My dell precision 470 has a loud beep sound for a few seconds when i turn it on and the monitor has no signal any ideas?no signal when i plug the monitor
Please refer to error codes for your system here:
May 27, 2012 | Dell Precision 470 PC Desktop
What type of vga card do i need for a dell precision 470
To take Full advantage --You have High-Speed PCI X (express) slot-(if its not already being used for something else)--and dont forget that you will need to disable the integrated one first.
Jan 02, 2011 | Dell Precision 470 PC Desktop
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
I have a dell precision m60 and I want to hook it up to my hitachi 55 plasma tv Ive tried to do this via s-video without success
Trying to hook up your computer to the tv? Or the monitor to the tv? Anyways, you can't hook up the monitor to the tv to see the same thing on both. But for the computer to the tv, connect the s-video cable to the tv from the computer, and you have to press (on the computer) ctrl+alt+F2 or ctrl+alt+F1 it's different for some computers. But if that's what you tried to do, that's the way you do it.
Anyways, hope this helps.
Jul 14, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I would like to know if I can use the DVI-HDTV input terminal to plug in my computer and use my Hitachi 65S500 as my monitor with a wireless keyboard and mouse.
Yes. You need to have a DVI connector on your PC for direct DVI-DVI connection or you can buy a DVI-VGA cables for around $25 bucks. Then, after connected, go into your display properties and adjust your settings. Hope that helped.
Dec 22, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Hitachi CMP205SXU 25 in. Plasma Television Logo
568 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
