Question about Garden
HOMELITE Textron Chain Saw, wont stay running properly.
I have a HOMELITE Textron Chain Saw, the thing wont stay running properly.
I think the adjustments are off for the slow and fast adjustments on the carberator, What are they supposed to be at(how many turns out)? Thanks.
Left my chain saw xl12 in the garage and the gas dried up need to rebuild the carb and clean up the gas where do I get a gasket kit so I can start for this unit
Posted on Feb 24, 2010
  • 3 Answers
The preset is to turn them all the way in (Don't tighten them hard or you will damage the needle) and then back each out 1 1/2 turns. This will get you started. You can then run it at full throttle and turn the high speed jet in untill you hear a change in the RPM. Then turn it out untill you hear the same. Find the happy medium.
Posted on May 15, 2009
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
I have a Homelite-terry TEXTRON chain saw does it take a gas oil mixture?
I have a Homelite Terry Textron X76 T83-03010 Unit 50150.
how do you change the fuel line?
Sep 02, 2012 | Garden
Need a manual for homelight textron super ez automatic chainsaw serial # 292740092
You can download then print your Homelite manual by going to www.homelite.com/service/product owners manuals the best way to do it is to right click on the material, left click save, put in in your Documents folder, then retrieve it to print if you actually have to hold paper. Good luck
Sep 23, 2011 | Homelite ZR10926 16 Chain Saw
Spark plug gap for homelite textron ut 10080c chain saw
Hi idone8...
Set your gap using a round feeler gauge to .28 to .32
Please take time to rate me
Sep 08, 2011 | Garden
CHAIN SAW WONT STAY RUNNING
PLEASE stop shouting and provide a model number for your saw. I will provide an IPL with some fuel system detail and a schematic to use for hose replacement. Reply below. Lou
Mar 15, 2010 | Homelite Garden
Can i get parts for homelite textron chainsaw 10045b
I saw no Textron listed. An inspection of your saw will probably reveal a "UT-", that seems to be the key.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches. Good luck
Lou
Jan 20, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I recently bought a 12" homelite xl textron chain saw @ yard sale. it runs good but leaks gas. it has a hole in top of gas tank, it looks like a factory drilled hole with nothing in it. is this hole for...
I dont know where the fuel is leaking from but i`ll make a guess and say the fuel lines are perished.NOW all you have to do is disassemble it taking note of where every thing goes and replace them ALL.... not hard just have a good look at where things go before pulling them apart , you will manage
Aug 25, 2009 | Garden
Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
1,153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
