Question about Cycling
Parts for autobike
I own an Auto Bike but one little plastic piece which pushes against the derailer is broken I made a new piece which seems to work but would like to buy a new component. I believe AutoBike is closed does anyone known if spare parts are available
  • Anonymous Mar 30, 2014
    I a rand trail blazer bike the serial number is w980551892 I would like to know how speeds it has and where to order a new derailer and a new pair of peddles for it
  • 718 Answers
This company is now called LandRider
You can contact them at;
http://www.landriderbikes.com/?src=google&gclid=CMnjx8WrsJoCFRAhDQodEkKkbw
Posted on May 09, 2009
I have a autobike classic. I here a clicking when I peddle as if the chain not engaging when it shifts. Derailed seems off centerd? What to do?
The cable adjuster for the D?railleur is not correctly set.
Download the adjustment instructions from the manufacturers website.
Jul 17, 2015 | Cycling
I have a Kawasaki kx20s 10 speed boys mountain bike that needs the rear brake cable replaced and both the front and rear derailer gear cables adjusted or possibly replaced. Is there a manual or diagram of...
1st The brakes: Once you have ran the cable through appropriate cable holders and to the brakes-you hold the brake calipers shut-remove excess slack from cable by pulling on it with pliers and back off a little before tightening the nut holding the cable(amount you have to back off tension depends on how strait your wheel is).
The Front Derailer doesn't usually have adjustment so you put the gear lever in top gear-loosen the nut holding the cable-push the derailer into the right position-remove slack from cable with pliers then tighten the nut.
The Rear Derailer: will need to be done the same way if your running a new cable..*But there is a screw on the derailer near the junction of the 2 parts that adjusts the position of the derailer- so you can do minor adjustments-**NOTE-there are 2 screws- 1 changes the position in or out and the other changes the angle**
Aug 26, 2011 | kawasaki KX20 Boy's BMX Bike
When I shift it's not smooth but the chain seems to jump all over , same thing happens when I put extra pressure on pedals
If it used to work and the cables are new then the cabels streached as normal you need derailer adjustments. If you have had it a while, and recently fell then you bent your derailer hanger take it to a bike shop to be straitened by a pro.. If it is a new bike and never worked at all then you need some derailer adjustments. You can adjust your derailer your self IF you know what you are doing. Otherwise go to a bike shop and have them do it. .
Jul 10, 2011 | Mongoose Cycling
I have a sears aircompressor model# 919.163450 Broke off intake muffler How do I get the rest of it out {plastic sleeve in head housing}?
Hello, what I do when I have a problem like this is I find a piece of metal (chisel, screwdriver) that fits the inside of the broken part (the tool is slightly larger than the inside diameter of the sleeve) and push firmly while turning counter-clockwise removing the broken plastic sleeve. Sometimes, if a tool will not fit on the inside of the sleeve, then I push it against the broken stub of the sleeve, and push against the stub while turning out the sleeve. I hope this helps.
Jan 11, 2011 | Garden
Where can I find a reset button that went bad on my model #51591 Toro Super Blower. Toro direct told me they don't have the part any longer. Not happy about this it's just a stupid little button that can...
I also had problems getting my toro 51591 to work. I too discover the safety/kill switch. i used a screwdriver to push it in the hole and activate the machine again. it started right up. I too was going to(and am) find something to put in the hole(like a screw/nail to override and keep the machine from stopping again.it would be nice if they would tell about these safety items. like that they exist ,& where they are located, and how they work. so first try to just rest it by using the screwdriver to push the rest button. it is located on the bottom . it is just a small rectangle where the plastic part is suppose to fit . mine showed a white color filler. plastic part probably broke off and is now too short. so need to do the nail/screw trick to fix it. with duct tape. good luck
Dec 02, 2010 | Toro "Toro" Super Blower/Vac
My rear window won't go up or down and I pulled it apart and the cables were frayed and out of the little pulley, I think it is the regulator. Can I replace this easily myself or should I take it in.
You got a broken plastic parts of your window riser, and that's the cause of derailment. If you can find the broken part, use dual epoxy to bind them.Align the nylon teeth on the gears....If the nylon gears and teeths were broken then you have to replace the whole part.
Oct 07, 2010 | 2007 Dodge Nitro R/T New Cars
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
May 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Battery door broken
You're making it harder than it has to be. Simply hold the camera in your left hand, and open the battery door so it is standing up. Look closely at the lower left corner of the batterry door. Notice the notch shape. The door plastic door is locked in place by the mating little "L" shape on the hinged door of your camera. Thats all that keeps it from sliding off when you put in batteries. Simply insert a small screwdriver or knife blade in that slot, twist it counterclockwise to push the battery door lock to the left, and slide the door off with no force at all. It's a snap.
Jan 15, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cycling Logo
581 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
