Question about Likom HD15A 15" LCD Monitor
Umax lcd screen HD15A
There was something wrong with the screen. I got it fixed but when I turend on the screen it was dim. I could see the images and words on the sreen but too dark and very dim light on it. any ideas. I am thinking there is a problem with the inverter but I am not sure. any help would be appreciated.
  • Anonymous Dec 13, 2007
    Where can I get a replacement Inverter for the Likom HD15A LCD monitor?
    I've looked everywhere, even the manufacture with no luck!
2 Suggested Answers
SOURCE:
  • 125 Answers
SOURCE: The monitor cant view video
To use the external vga connector of a laptop, you have to activate it. In many notebooks it is Funtion and F7 (Fn-F7). In your notebook it may be F5 or F6, look for a monitor sigh in the F keys. The activation may sometimes rotate in sequence , ie, External + LCD, LCD, External... and so on.
Posted on May 15, 2007
My hp coa-se laptop mdl 661631 fhe screen is so dim u cant see it... how do i fix it?
The image on your screen is made up of two parts the lcd screen that creates the image that you can see dimly and a backlight that shines trough the screen brightening it so you can easily read the screen. In your situation in would appear the backlight bulb is burnt out and needs to be replaced. If your handy this is something you could do yourself a search on google for "backlight" and your specific laptop model will bring up available replacement bulb and quite possible detailed instructions on how to replace
Feb 07, 2013 | Computers & Internet
I need to know if my lcd monitor Likom HD15A you can change the resolution d epantalla over 1024, I have SO please confirm W7
No, that is the native resolution of your LCD Monitor, it can not display a higher resolution.
Apr 12, 2011 | Likom HD15A 15" LCD Monitor
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Dim screen
Your LCD has a small problem its cold soldering. Its a factory depict try to fix its on electronic shop...
Aug 08, 2009 | Dell Computers & Internet
Dim Screen when Power is Unpluged
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 27, 2009 | Dell XPS M1330 Notebook
Laptop screen flickers
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | Acer Aspire 5920-6335 Laptop
Full screen on my laptop only shows black screen but i still hear the sound how can i fix this
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 16, 2009 | Acer Aspire 4720 Notebook
Dark unreadable screen
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Need an Inverter for Likom HD15A LCD Monitor
Go links:
http://www.aitendo.co.jp/product/230
http://www.garitto.com/product/index/3804758#review
Dec 13, 2007 | Computers & Internet
May 15, 2007 | Likom HD15A 15" LCD Monitor
Likom HD15A 15" LCD Monitor Logo
43 people viewed this question
Top Likom Computers & Internet Experts
Ekse
Alun Cox
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
