Question about Fuji FinePix S3500 Digital Camera
Finepix Z5 Troubleshoot
The flash on my camera doesn't work. Even when I set the mode to forced flash, I still get no flash.
  • Anonymous Jan 05, 2008
    I have the same problem... I think that maybe it's broken
  • 3 Answers
The problem is with either the flash unit, or the flash transformer. Unfortunately the only way to fix this, is to take it to a service center.
Bob
Posted on Feb 26, 2008
I can't get my fuji finepixz5 to take sharp pictures....why is this? I have tried all the different modes and even taken a class...help
Posted on Oct 26, 2009
My camera is doing the same thing.. but i dont understand why!!
Posted on Aug 18, 2008
Fujifilm Finepix AX Flash Is Not Working/Turning On
If your camera is in "silent mode" the flash will not work. Press and hold the Disp/back button for a few seconds and the camera will toggle between "silent mode" and "normal mode"
Oct 09, 2014 | FUJIFILM Cameras
DSC-55 camera flash doesn't work even though in Flash "Auto" setting in Easy or 'i' mode.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  1. When shooting MPEG movies
  2. When shooting in the Twilight or Handheld Twilight mode
  3. If shooting with the Burst or Multi Burst mode
  4. Shooting with Sweep Panorama
  5. Shooting with the Fireworks or High Sensitivity mode.
  6. If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
  • If the issue persists, please reset the Camera and make sure that battery is fully charged.
  • If the issue persists after performing all the above-mentioned troubleshooting steps, service is required.
Thanks for understanding.
Mar 13, 2011 | Sony Cameras
The flash will not come on
I'm sorry that the flash on the Camera is not working. If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
- When shooting MPEG movies
- When shooting in the Twilight or Handheld Twilight mode
- If shooting with the Burst or Multi Burst mode
- Shooting with Sweep Panorama
- Shooting with the Fireworks or High Sensitivity mode.
- If an external flash is connected
Please make sure that the Camera is not in any of the above modes.
Feb 21, 2011 | Vivitar ViviCam 5022 Digital Camera
Flash does not work no apperant cause
- When shooting MPEG movies - When shooting in the Twilight or Handheld Twilight mode - If shooting with the Burst or Multi Burst mode - Shooting with Sweep Panorama - Shooting with the Fireworks or High Sensitivity mode. - If an external flash is connected
Jan 22, 2011 | Kodak EasyShare Z612 Digital Camera
Flash is not working
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Dec 31, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
I have a Camera Sony alpha 350 but the Integrated flash doesn´t work more ,the failure began the last week, even I forced the flash using the camera by the night in automatic mode but nothing :(
press menu button then go to the tab with the wrench icon then go to number 3 tab the select reset default(its not going to delete pictures but it will only set it back to its factory settings.)
Sep 07, 2010 | Cameras
FORCED FLASH NOT WORKING
Hi,I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Aug 14, 2008 | Fuji FinePix Z1 Digital Camera
Flash not working
pop up the flash and you can select flash mode by pressing the arrow like button press right to select the flash mode....
Jun 16, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Z5 flash
uhm mine did to. most definetley ship it in. it's under warranty. if you reset it and it still doesnt work then ship it off.
Mar 23, 2008 | Fuji FinePix Z5fd Digital Camera
Fuji FinePix S3500 Digital Camera Logo
375 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
