Question about Garden
Runs good without air filter, but badly with air filter. New air filter no help. The engine was partially submerged in hurrican Ike and a new carburator was just installed. With air filter in it runs very rich and smokey, no power and won't go to hi speed.
  • Thomas F. Schneider May 11, 2010
    Still sounds like a restricted air filter. Factory filter? Installed correctly?
  • 246 Answers
Hello
Check the Exhaust Port and Muffler.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
If the Exhaust Port and Muffler are Clear, then
Check the Carburetors Metering Needle Valve.
If the Metering Valve Plunger (on the Carburetor Metering Jet Diaphram) is Set too Close to the Needle Valve Actuator Arm, then you will have this Problem.
I Require the OEM and Model Numbers Off the Carburetor to be of Better Assistance to you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
I have a 2006 Chevy Malibu that was partially submerged in a flood due to the hurricane. I don't believe the engine had any damaged because the front end was not submerged but I believe the computer...
Plenty. Dry all the controllers and scan system. If a controller cannot be accesse check all connections for dirt. Remove and reconnect all connecotrs. Re scan and you will be surprised.
Nov 09, 2012 | Cars & Trucks
1995 chevy tahoe 4wd. 5.7 liter when cooled down, starting is normal . Right after, engine almost stalls but Idle air control kicks in and keeps it running. eventually it is idling but rouph. On...
If your vehicle has one, and I think it does, check your EGR system. If the egr valve is full of carbon, it can be partially open, creating a vacuum leak. If the egr valve solenoid is bad, it could be opening the valve at the wrong time, also creating a vacuum leak. Unplug the egr vacuum hose, plug the open end of the hose and start it and see what it does. A picture of the egr is below.
Mar 11, 2017 | 1995 Chevrolet Tahoe
My freezer not getting cold. it is about 10 yrs old and after Hurricane Ike it stop freezing.
if the fan run and does not freeze, possible compressor or compressor start kit. Start kits that a beating in stormy weather. Start kits consist of a relay, capicator and overload sensor. These 3 parts can be ordered seperately or a generic start kit with all the of these made in one. if the compressor is bad on a 10 year old freezer you might want to look at a new freezer
Feb 28, 2010 | Kenmore 65802
Having hard time with new poulon 18" chainsaw starting.
Since you have good spark and good gas the only things left to check are the air filter and the carbeurator. If the air filter is dirty, replace it. While you are at the auto parts store also pick up a can of a gasoline additive called seafoam which will keep your carb. clean. Finally get a can of spray carb. cleaner and put a couple short squirts directly into the air intake which is right there when you remove the air filter.
May 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No power
sounds like a carb problem, you should have them cleaned and re-built
Apr 11, 2009 | Light Outboard Motor Boat Bass Fishing...
Power company turned power off for line repairs - tv no go since
most likely fuse, main a/c filter, shorted bridge-diodes. this occurs often when surges of up to 220v line is run into house. we've had alot here in south texas after HURRICANE IKE. good-luck mch
Feb 20, 2009 | Sanyo DS32224 TV
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
