Question about Konica Minolta Magicolor 2450 Printer
Printing an A3 document on an A4 printer
I am trying to print some A3 pdf documents on an A4 printer. If I print normally, they come out as A4. I could use the zoom feature on the print menu, but then I would just have the first half of the page to be printed on one A4 sheet. How can I get the second half on a different A4 sheet.
I have a Minolta Magicolor 2450. I have looked all through the printer settings. It has excellent choices for printing multipage - but no 'poster' feature, such as some printers have.
Any ideas?
    New Friend:
My printer offers a so called "Poster Mode" (Canon IP5000). Here I can define how many pieces I'd like to get.
Posted on Jan 09, 2010
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Posted on Jan 04, 2009
SOURCE:
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
I have an error msg saying load plain letter SSF 024-969
I guess that you normally use A4 paper. If this is the case you are most likely printing from a document that was created using the Letter paper size (typically a Word Doc of PDF file created in the USA). The solution is to reformat the document that you are trying to print, to A4. You may change the formatting of the document when doing this and page numbers may be incorrect when compared to the index and contents pages.
Oct 15, 2009 | Dell 2130cn Laser Printer
Print A3 to 4xA4 pages on Lexmark X4270 All In One
Hi!
Please download this software for converting your dwg, dxg,etc files into jpeg---
Dwg to jpeg Converter
And, regarding printing in black color only, you need to give it a print command and the click on prefrences button and from there select print in grayscale and then you will be able to print.
Please ask for any further clarifications.
Please rate this solution as Fixya if found helpful.
Thanks
Rylee
Feb 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer problem
From the Printers & Faxes window, check in the i9950 Printing Preferences, Page Setup tab, for the following settings:
Page Size and Printer Paper Size are both set for the same size (both A4 or both A3).
Printing Type is set for Normal-size Printing
The graphic on the left should now show A4 (or A3) and Normal-size Printing in the legend.
Once that is set, verify from the application you're printing from that these settings are not being changed by the application (Preferences button in the print dialog box).
Jun 16, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Hi, I am using ms word 2007 and need an a3 sheet format. Its not in the page set up drop down menu and the only solution I have is to customise my page size. Even doing this however, and increasing my...
The print sizes available are dependent on the printers installed.
If you don't have an a3 printer installed on your computer, there won't be a A3 option in word.
if you install a standard pdf printer like cutePDF(simulates printer, but instead of printing document on paper, it generates an adobe pdf-file from the document) the option should become available in your dropdown.
Apr 04, 2008 | Computers & Internet
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Feb 14, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Printing from wrong tray
Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
Jan 24, 2008 | Office Equipment & Supplies
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
Konica Minolta Magicolor 2450 Printer Logo
2,565 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
