L have a mouse with tackball
But the ball is missing
    Scholar:
  • 45 Answers
Sounds like it is time for a new mouse.  They are pretty cheap ($9-30.00)
Posted on May 10, 2009
Mouse with its own mind
If the mouse has a ball, it probably needs cleaned along with the wheels inside behind the ball. Always do all maintanance with the mouse unplugged from the computer. You can see them when you take the ball out. Typicaly, you twist the cap holding the ball in and it just falls out. At this point, you can clean the ball with a mild cleaner and the wheels inside the mouse with a pencil eraser, pocket knife or a Q-tip with rubbing alcohol.
If it's an optical mouse (red or blue laser under the mouse) simply clean where the laser light is. If this does not work, then plug the mouse into another USB port. If that does not work, then restart the computer properly (not hard or soft reset). That should fix it. If not then the mouse probably is bad.
Mar 14, 2015 | Computers & Internet
Tip
How to Clean Your Mouse
<p><b><span>Roller Ball Type:-</span></b><br /> <p><span>For cleaning your mouse you have to do the following work.</span><br /> <p><span>1. Disconnect the mouse from your computer CPU.<br /> 2. Turn the mouse upside down and twist the roller ball retaining ring in a counter-clockwise direction to remove the ring.<br /> 3. Remove the roller ball from the mouse cavity.<br /> 4. Wash the roller ball with warm soapy water and put it in dry place.<br /> 5. Replace the dry roller ball back into the mouse cavity.<br /> 6. Replace the roller ball retaining ring and twist it clockwise to tighten.</span><br /> <p><b><span> </span></b><br /> <p><b><span>For Laser type Mouse:-</span></b><br /> <p><span>A laser type mouse requires very little care. Internally, there isn't anything required of you. If it should get a little dirty on the outside, just dampen a soft cloth with water and wipe it until it is clean.</span><br />
on Dec 24, 2010 | Computers & Internet
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
Mouse will not mover cursor but will right and
Does your mouse use a ball for movement?
Look at bottom of mouse. If so you could have a ditty unit. You can turn the ball cover counter clockwise and remove the ball. Clean the ball and the rollers inside the mouse. Replace the mouse ball and cover and retry the mouse.
Jan 28, 2010 | Computers & Internet
My mouse pad will not move my cursor on my computer
If your mouse is the older ball type hold the mouse level about 12 inches off the pad and move the ball on the underside of the mouse with your finger. If the cursor moves you may need to simply clean any dust from inside the device and clean the ball. Open the open to release the ball. Theres a round plate on the underside around the ball. Turn it to the open position a remove the ball. Clean any dust from inside with canned air or a soft brush. Clean the ball with a small amount of alcohol and let dry completely. Replace ball and plate and you should be ready to go.
If you have an infrared mouse, your mousepad may be too glossy. Dry a pad with a dull finish.
Jan 18, 2010 | Computers & Internet
Pointer jumps
That's not a lot of information there...
How far does it jump? How often? Since when? Is this a new mouse, an old one, an optical or a ball mouse? Do you use a mouse pad? Have you installed any of that cursor mania stuff? Is it a USB mouse?
I'd recommend (If you have a ball mouse) to take out the ball by turning the circular plate under the mouse then blowing the dust out and wiping the ball clean. If it's an optical mouse i'd suggest a new mouse-pad designed especially for this optical mice. Also you might wanna try re-installing it. Or if it's a USB mouse trying it in a different slot and cleaning out that connection too.
Dec 24, 2009 | HP Wireless Optical Mouse
Mouse somtimes sticks
unscrew the ring that holds the ball in place and remove the ball. clean out any lint, or dust, etc on the ball and inside the mouse where the ball sits and rides. once it is clean put the ball back in and replace the ring. that should solve your sticky mouse problem
Oct 25, 2009 | Dell U0636 Mouse
Dell Mouse Scroll Ball Wont Work
If it really _has_ a ball, the rollers inside the ball compartment get clogged with gummy matterial & needs to be cleaned thoroughly - also sometimes the dirt & dust need to be blown out as they can cover the light sensors
Mar 25, 2009 | Computers & Internet
I have model pc7530
Are you using an Optical mouse, Wireless Mouse or a Roller Ball mouse? If its a roller ball, turn it over, twist the cover as the arrows show, remove the ball and you will see some rollers around the edges that read the balls movement. Clean the gunk off of them with your fingernail or cotton swab. (NO WATER)
If you are using a wireless mouse, change the batteries and make sure you have a good line of site to the wireless adapter, and RESET the mouse by pushing the button on the wireless adapter. If it is an optical USB mouse please let me know, if any of the above worked. Thanks //D
Apr 25, 2008 | RCA (PC7530) Keyboard
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
