Question about Apple MacBook White- 2.1GHz Intel Core 2 Duo, 2GB DDR2 , 120GB SATA HD, Combo Drive ,... Mac Notebook
I have a new MacBook White. Everytime I am on Safari for any period of time my computer begins to chime every 10 seconds. I have checked to see if I had anything else open but did not. Any idea what is causing this?
  • Apple Master
  • 4,338 Answers
Reset Safari:
Click on Safari in your Safari menu, located at the top of your screen. A drop-down menu will now appear. Choose the option labeled Reset Safari
This will give you the option to delete stored login info, favicons, cache, history, and cookies. If you do a full reset you’ll likely see noticeably improved browser performance, but you’ll need to log in to all the websites that normally “remember” you, so if you doubt you’ll be able to recall all of your login info across the Web, try deleting everything but login info and cookies first to see if that speeds things up.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 20, 2009
  • JDTec
    JDTec May 21, 2009
    Try a Safari reset:
    Thanks, Joe
MacBook Pro does not start. Gets stuck on the apple logo
Have you tried a PRAM start?
Switch machine off. Restart> when you hear the first Chime, hold down the following four keys at the same time (tricky but can be done) ALT>CMD>P>R. Keep them held down until you hear the second Chime then release.
Feb 02, 2015 | Apple 15.4" MacBook Pro Notebook Computer...
I have a Macbook Pro, 17". I've gone to the
Sadly, there is nothing you can do short of installing a third-party popup blocker. The Safari blocker does work, however advertisers are always finding ways around current blocker programs and it's hard for any one blocker to keep up with every new trick.
Apr 14, 2011 | Apple Mac OS X
White screen of death on Macbook 13". when turning
You may need to reset the PRAM.
Start your computer and hold down the option, command (apple), P and R keys simultaneously until you hear the second chime. Then release.
This will reset the perimeter RAM (PRAM) and may allow your system to start, which it will do immediately if it capable.
If this is not the case and you have already tried removing the RAM and the HD, you may need to have the motherboard tested.
Oct 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cannot quit safari before beginning this update
Thank you for contacting Fixya Support
In order to quit Safari before updating, if the web browser cannot be closed normally, you can simply perform a Force Quit by pressing the Apple Command Key + Option Key + the Esc Key and this will bring a window up displaying all currently open applications including Safari.
If you see that Safari is listed in that window, it should have a "Not responding" tag next to its name.
Simply click on the Safari name and press the Force Quit button and it will close out the Safari application.
If you require more information or assistance with this issue, please don't hesitate to reply to this post.
Regards,
-Mactechtrainer
Jun 26, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book chimes on start up but no screen comes on
Make sure the MagSafe adapter is securely attached to the Macbook and free of debris.
There are two procedures that are advised by Apple to assist in resolving issues where the Macbook chimes at start up, but displays no video.
Here is the first procedure:
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Macbook to start up.
Observe to see if your Macbook will boot to the Desk top normally. If it does not, here is the second procedure:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect the AC adapter and remove the computer's battery.
• Press and hold the power button for 5 seconds
and then release the button.
• Reconnect the battery and AC Adapter.
• Press the power button to restart the computer
Update me if you require further assistance.
Regards,
-Mactechtrainer
Jan 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macbook pro starts up but i dont get the chime and no screen start up?
Most likely fix is to reset the SMC.
Turn the power off, remove all peripheral cables, connect the AC power supply. Using the left-side keys, press the combination Shift-Control-Option-powerbutton ONCE. The LED on the MagSafe connector
should go off, go back to green when keys are released, and may change to orange if the battery still needs some charge. Wait five seconds, then press the power button to restart the computer.
Dec 11, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
White macbook 13 icnh 2 years old. when using skype calls keeps dropping and computer hangs when using safari
Boot your system from Install disk 1, and run disk utilities from the menu.
run 'Check disk' until there are no more errors and then run 'check file permissions' until no more errors. Then reboot and try SAfari and SKype again. Hope his helps
Aug 11, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Display Color
check your display setings,,change the resolution,, if not download a new video driver
May 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Safari quits
maybe because your computer cant run on it
Jul 17, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook White- 2.1GHz Intel Core 2 Duo, 2GB DDR2 , 120GB SATA HD, Combo Drive ,... Mac Notebook Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
