Question about KitchenAid KGSA906PSS Gas Kitchen Range
After self cleaning cycle on my Kitchen Aid kgsa 906, was finished the door opened, but the next morning the door wouldn't open and the control panel was blank
  • 25 Answers
You may be experiencing the dreaded Thermal Fuse overload problem.. search the other posts, i've included easy steps to replacing it..
(you may want to check yours for continuity with a radio shack tester before you buy a new one)..
good luck
tpug
Posted on Jul 22, 2009
Kitchenaid thermal fuse malfunctioning? Sounds like there are 100's of this same issue involving the thermal fuse. Anyone interested in a class action lawsuit against Kitchenaid? Email me at tarstime@earthlink.net. If there are enough of us... I will take this issue to an attorney,
Posted on Jul 11, 2012
  • tarstime
    tarstime Jul 11, 2012
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Whrilpool gas range Mod. GW395LEGD0 Serial IMJ0663181 OVEN DOOR LOCKED CAN NOT OPEN
If its a self cleaning model and you tried to stop it in the middle of the cleaning cycle the door will not unlock. Disconnect it from the power, let it stand a few hours then plug in. If not opening try running the self cleaning mode and let it finish completely. When it finishes after it cools down sufficiently the door lock should go off.
Aug 09, 2014 | Whirlpool GS460 Gas Kitchen Range
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
    Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
    Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
    My oven is locked and wont open. it is cold and wont unlock
    Hi
    Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
    If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
    1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
    2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
    If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
    In order to open the door you have to open the control panel and remove the door lock.
    Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
    The door lock is secured by the three screws.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
    How to turn off self clean oven Jenn air slide in older model after it is done cleaning
    the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
    Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
    Oven Lock stuck open before start of self-cleaning cycle
    Sounds like you bent the door where the lock is. You might have to replace the door.
    Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
    Ge wall oven door will not open
    If you can not open this door, then the problem probably is that you stopped the clean cycle before it was finished. Restart the cycle, and set it at the minimum of 3 hours, and then when it is finished, it will release the latch that locks the door. I had this problem last night, and after the cycle was finished, the door latch was released. Hope this helps.
    Take Care
    Feb 14, 2009 | GE JBP70SKSS Stainless Steel Electric...
    Kitchen Aid Superba Wisper Quite will not start cycle
    Intermittent door switch, should be available, easy to change out and inexpensive.
    Aug 04, 2008 | Dishwashers
    KitchenAid KGSA906PSS Gas Kitchen Range Logo
    358 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Dan Webster
    Dan Webster
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
