Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi SS30 Problem, please help
Got a Ryobi SS30 at a gragare sale. It looked in really good condition and good price. I started using it and about 20 minutes into working, it stopped... as if it didnt have gas - but it did. So I tried to start again, but the pull cord seems to be stucked. I wont pull. Any ideas?? Thanks
  • 246 Answers
Hello:
Are you Sire you Used the Correct Fuel Mix Ratio?
Remove the Muffler and Look Into the Exhaust Port.
Is the Piston Scratched and Gouged or is it Smooth like Glass?
If Smooth like Glass, then Check the Carburetor for Trash.
If Scratched and Gouged, then the Wrong Mixture was Used and the Engine is Trashed and will Require a New Piston and Jug (Cylinder) Assembly (a new unit will be cheaper than the parts to repair this unit) for the Unit to Run again.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi SS30 does not start
check to make sure the plug has good fire if not change the plug
Dec 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi SS30 and everytime I start it up it starts making this rattleing sound. Is there any way to fix this?
that rattling noise is the spindle inside the shaft the olny way of i know to fix is to replace the shaft
Nov 13, 2010 | Ryobi Garden
My Ryobia SS30 SS# ATJ0830439,weed eater, the pull cord will not retract please help Thank You Gail
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Apr 28, 2010 | Ryobi Garden
How much is it worth used?
I can't give you a definative answer for your particular Sony DSR-11DV as the second hand price for one of these is going to depend on a few area's: the overall condition, that it functions correctly, it has it's accessories (leads, remote etc) and also how many drum & tape hours the machine is showing. Looking at ebay as a reference point for a general price in pounds sterling it looks like:
Used, working, below average condition, showing damage, around £260
Used, good condition with around 200 drum hours around £320
Used, working, below average condition with 20 drum hours £370
Used, good condition (accessories inc) with 31 drum hours £525
As I stated above the price can vary considerably, also the market can change and subsequently prices can fluctuate. These prices were obtained from finished auctions on ebay in April 2010.
Hope this helps,
James
Apr 20, 2010 | Sony DSR-11 DV / Mini DV VCR
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
997 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
