Question about Canon imageCLASS MF4150 All-In-One Laser Printer
I got it working, install print drivers from canon's site, then add printer then install FAX drivers if you choose, when i installed both drivers then tried to install printer, it did not let me choose the right drivers for the printer... Image Capture won't detect it...
    Sergeant:
  • 186 Answers
I will give you a easiest way for finding the drivers that you needforyour hardware.Just download the software named drivermagician.Installit and it will search for the drivers that is notinstalled for thehardware you have through internet and will downloadit for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
Posted on May 22, 2009
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
How to install canon 3220 to the network for printing
Hello ,actually its a very easy way to install canon 3220 to a network just download the driver from canon official site :software.canon-Europe.com
go to printers and faxes add printer press local then next choose create port choose stranded tcp/ip write down the same ip of the copier then press next ,choose have disk and specify where the file u download it from the site and after that choose from the menu canon clc3220 c1pcl5 then press ok so now the printer driver is defined. now at the other side (photo copier ) press * system management network settings choose TCP/IP and give the machine IP turn off and the on the machine to save the changes .now the machine is connected through the network :) for more assistant t here is my email mramlawi@gmail.com regards :)
Nov 09, 2010 | Canon imageRUNNER C3220 Color Copier
How can i install my printer without a cd
Hi
please follow steps to setup your printer
Install a printer driver locally Installing a printer driver is a Windows function, not a PowerPoint one. Before installing a printer driver, quit PowerPoint and your other programs.
Read over the installation instructions that came with your printer. When in doubt, follow the instructions there rather than the ones below.
  • Click Start, Settings, Control Panel.
  • Double-click "Printers & Faxes"
  • Double-click "Add Printer" to start the Add Printer Wizard
The Add Printer Wizard Welcome screen
  • Click Next
Local or Network Printer
  • Click "Local Printer"
  • Make sure there's NO checkmark next to "Automatically detect and install ..."
  • Click Next
Select a Printer Port
  • If your printer is actually attached to the computer, click "Use the following port" and select the port your printer's attached to.
  • If you're installing a driver only to keep PowerPoint happy, choose LPT1: or FILE: (it doesn't really matter, since you'll never actually print to the port)
  • If you're installing a local driver but need to print to a network printer, look for the printer's port on the network and choose it, if available. If not, choose LPT1: for now. You can change the setting later.
  • Click Next (please select canon from list)
Install Printer Software
  • If installing a real printer, select your printer manufacturer and printer model here.
  • If you have an installation disk or CD that came with the printer, click "Have Disk" and locate the INF file for the printer (check the printer's documentation for specific instructions).
  • If installing a printer only to keep PowerPoint happy, choose the HP LaserJet 4V/4MV as we've done here
  • Click Next
Name Your Printer
  • Give the printer a name (this is the name you'll use to select it later)
  • If installing a printer just to make PowerPoint happy, you might want to give it a name that indicates it isn't a real physical printer (PPT Pacifier, or the like)
  • Click "Yes" under "Do you want to use this printer as the default printer" (this option may not appear in all Windows versions; see Notes below)
  • Click Next
Printer Sharing
  • Click "Do not share this printer"
  • Click Next
Print Test Page
  • Click No
  • Click Next
Completing the Add Printer Wizard
  • Review your choices. Click Back if you need to change anything
  • Click Finish
Apr 04, 2010 | Canon PIXMA iP1600 Printer
How to fax by using canon mx310
Make sure in printer list fax printer driver is installed if it is not there then reinstall the printer driver it will install the fax printer. When you want to send the fax from any application then you have to choose print option and choose the fax printer. It will prompt you for dialer window put the fax no and send the fax.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 23, 2010 | Canon PIXMA MX310 All-In-One Printer
I can not get my canon pixma mp600 to print from my computer.
Can you install your printer driver?If you do this so connect printer with computer, click start choice settings -Printer and Fax-Add Printer then Quarry your printer which you want install.
Dec 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How to print to fax using the canon imagerunner 2020i
On the installation cd's of the machine there is a fax driver if you install the fax driver the fax is showing as a fax in the printers and faxes in the controll panel.If you print to the fax a window will open where you tipe the name and number you want to send the fax to.There is also a option if you want to add it to the addresbook.After editing the info add it to the receipient list and send.Your document will faxed from your computer via the IR machine,if your machine is connected to a fax line.
You can edit the address book easy by logging to your machine via your broser tipe the ip address of the machine in your browser and press go.If the machine is connected via local LAN.
Nov 16, 2009 | Canon Office Equipment & Supplies
Canon imagePROGRAF W7250
I did not see that there was a response on Apple's support site that adds to the previous post I mentioned. Combing the steps from the two posts, I was able to get our W7250 to print from Mac OS X 10.5 Leopard.
Here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard :
1. Download garo34 print driver from Canon's support site here.
2. Download the iPF610/iP710 Leopard print driver from Canon here.
3. Double-click on the garo34_osx.hqx file that you downloaded.
4. A folder named Driver is created; open it and double click on "GARO Installer for X".
5. Enter a name and password of an administrator account on your Mac and click OK.
6. When the GARO Installer for X window appears, click on Continue.
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
11. When the installation is complete, click on the Restart button.
12. When your system has restarted, double-click on the iPF610_710_Driver_OSX_10.5_Ver1.10.hqx file you downloaded.
13. A folder named iPF610_710_Driver_OSX_10.5_Ver1.10 is created; open it and double-click on "iPF Driver Installer X".
14. Enter a name and password of an administrator account on your Mac and click OK.
15. When the iPF Installer X window appears, click on Continue.
16. Click Agree.
17. Click Install.
18. When the installation is complete, click on the Restart button.
19. When your system has restarted, click on the System Preferences icon on your Dock or select System Preferences from the Apple pull-down menu.
20. When the System Preferences window appears, click on the Print & Fax icon.
21. Click on the + Button underneath the Printers column.
22. Another window will appear; click on the "More Printers" icon.
23. A drop-down window appears; select Canon IP (GARO) from the pull-down menu if not already selected.
24. In the "Printer's Address:" field, enter the IP address of your Canon W7250 printer (e.g. 192.168.1.2).
25.In the "Queue Name:" field, enter a name for your printer (e.g. W7250).
26. Click on Add.
27. The W7250 is now your default printer. If you want another printer to be the default, change it in the Print & Fax preference pane.
Voila!
I hope this solves your problem and you found the instructions helful.
Mark
Jan 09, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Upgraded to Leopard and now need to update my printer driver
Canon will not be coming out with a Leopard print driver for the W7250.
However, here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard:
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
16. Click Agree.
17. Click Install.
26. Click on Add.
Voila!
I hope this solves your problem and you found the instructions helpful.
Mark
Sep 11, 2008 | Canon imagePROGRAF W7250 InkJet Printer
DRIVER
Follow these instructions carefully. Not 100% guaranteed to work. Remember - you must have printer connected by parallel cable and use LPT1 when asked. If this works just remember you'll most likely only be able to print. I'll check to see how it turns out. Choose the printer the instructions say to choose. Except the very last dtep you can name it whatever you want. Take your time, do it right. Doesn't take long.
Use the following procedure to place the MultiPASS in Printer Mode. When finished, install an emulation driver.
  1. Press the <Menu> button on the printer's operator panel.
  2. Press the <SCAN> button.
  3. Press the <COPY> button.
  4. Press the <SET> button 2 times. The display will display [PRINTER MODE].
Note:
  • After the printer is set to PRINTER MODE and the parallel cable is connected at both ends and the computer is booted into Windows, Windows Plug and Play will detect and automatically install the Canon Inkjet S630 printer driver. If the S630 is not installed automatically, install the emulation driver manually.
  • After printing is completed, disconnect the cable from the printer and then disable PRINTER MODE.
Installing an emulation driver
The Canon Inkjet S630 emulation driver should install automatically once the F50 is set to Printer Mode, the cable is connected at both ends and the computer has booted into Windows. If not, the driver can be installed using the ‘Add a Printer’ function in the Printers window (See steps below).
  1. After setting the MultiPASS to Printer Mode and connecting the interface cable, power on the computer.
  2. If the 'Found New Hardware' window appears, cancel it.
  3. Click the 'Start' icon, startikon.gif , click 'Control Panel' and then click the appropriate link or icon depending on the view.
  • Using Normal Vista View : printernewmenu.gif
  • Using Classic View : printerikonclassicview.gif
  1. Click 'Add A Printer'.
  2. Select 'Add a Local Printer'.
  3. Select 'Use an existing port' and 'LPT1: (Printer Port)', then click 'Next'.
  4. Select 'Canon' as the Manufacturer and select Canon Inkjet S630.
  5. Type a name for the printer if desired, check the Set as the default printer box if you want the printer to be the default printer and then click 'Next'. The printer driver installs. If a Printer Sharing window appears, select 'Do not share' and click 'Next'.
    Above example shows Canon Bubble-Jet S400 in the Printer name field.
  6. When the installation finishes, click 'Finish' or choose 'Print a Test Page' to test the printer.
  7. After printing is completed, disconnect the cable from the printer and then disable PRINTER MODE. To print again, set the printer back to PRINTER MODE and then reconnect the cable.
Disable PRINTER MODE:
  1. Press the <Menu> button.
  3. Press the <COPY> button. The display will show [DOS PRINTING]
  4. Press the <SET> button. The bottom row on the display will show [ON].
  5. Press the left or right arrow to select OFF and then press the <SET> button.
Mar 16, 2008 | Canon MultiPASS F50 All-In-One InkJet...
MP110/130 drivers for vista
You can download the drivers from Canon. Click on driver downloads and pick the Vista driver.
MP110
MP130
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
196 people viewed this question
old marine
old marine
