Question about Whirlpool 24 in. DU915PWP Built-in Dishwasher
No power to dishwasher even after checking circuit breakers, etc.
No power to push button pad
Posted on Jun 08, 2009
  • 11,896 Answers
Than the problem is due to faulty power supply or fuse. You can check both things with an ohmmeter and/or voltmeter.
Posted on May 09, 2009
No power lg dishwasher
A large dishwasher should have a dedicated circuit breaker in the circuit breaker panel, check to see if the breaker is on, tripped, or off, it should be on. If it is on, remove the panel cover and check for power coming out of the circuit breaker, if there is power coming out of the circuit breaker, check for power at the dish washer. Checking for power at the dishwasher may involve pulling the connector cord if any and check the power outlet for power, if there is no power outlet and the dishwasher is hard wired into an electric box, the electric box needs to be opened and the wires need to be tested for power, involving removing the wire splice nuts or wire nuts. Once the power is verified to the dishwasher and the washer is still with no power, a fuse should be sought inside the dishwasher control panel or that the power feed wires are properly spliced. A voltage testor is needed to test for power. electric shock hazard on live wires, please be carefull or call out a electrician or handyman if power testing skill is questionable.
Aug 11, 2012 | LG Dishwashers
The power went out and when the power was restored the dishwasher did not come back on,whats wrong?
the surge could have fried the circuit board in the dishwasher or maybe the house circuit it's hooked into. maybe first check all of your breakers in your breaker box just to be sure one of them isn't tripped
Jul 15, 2012 | Amana ADB1600AWW Builtin Dishwasher
Kitchenaid Dishwasher trips the 60-amp main breaker but not 20-amp.
Its possible that there may be load on that circuit from other appliances. Had an issue myself with stove and laptop on same circuit.
Check other appliance attached to the 60amp circuit (microwave, stove, kettle etc)
May 13, 2012 | Electrical Supplies
Is there a fuse on the Whirlpool 24 in. DU910PFG Built-in dishwasher? ... it just stopped working!
Good evening, There is no fuse that would shut down everything.Check for switch under sink or your home circuit breaker.Then it could be your door switch which shuts every thing down .It may be stuck open.Sometimes a door slam will get it going but still needs replacement.$40 part though.Switch is located behind console and can be checked with ohm meter.Sears Parts Direct shows blow up of your machine.
If it was your circuit breaker and it blows again ,you have a short and you'll need tech. to troubleshoot or maybe there is another load on that circuit (like toaster etc)
hope this helped
Aug 16, 2011 | Whirlpool 24 in. DU910PFG Built-in...
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not start after change in electric meter outside. Dishwasher "popped " when it was started Check all circut breakers etc- all fine
if you have 120volts at plug,chk for a breaker inside unit and again voltage inside unit at terms on cord,then if so chk motor for a breaker on the motor,some have built-in breakers,then check door interlock switch for continuity and proper operation, then if electonically controlled check for a fuse and burns on the circuit,you may have suffered a voltage spike,and do it soon,the power supplier may be liable if you can prove he disconnected the neutral and you only had 240volts,this could be a cause also as it becomes a voltage divider circuit w/o the neutral connected
Jul 29, 2009 | Dishwashers
Two days ago my LG dishwasher model lDF 7810BB worked fine. Yesterday I loaded it and the display panel will not light nor show any sign of power. I check the circuit breaker several times and all other...
Check for voltage with a multimeter at the wires very near the front, just behind the kick plate. Follow the incoming electrical wire in and remove the little plate the covers the wires/wire nuts. I have seen wires that appear to be connected properly but the circuit is open.
Or, even though the circuit breaker is not switched open, the circuit itself, supplied to the front of the dishwasher is not live/hot.
Good Luck!
Mar 08, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Dishwashers Logo
243 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
