Question about Fedders A7DH65B2A Dehumidifier
Compressor runs as does the fan but does not take any moisture out. Is in the basement & there is moisture there. All controls light up & appear to be working. It is less than 5 years old.
  • 148 Answers
Probably either recharging the refrigerant or filter or condensor coil dirty
Posted on May 10, 2009
Unit fan running but does not take any moisture out of the air....bucket has not even a drop in it for three days.....moisture on floor even in basement area
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1, 2 & 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a manually
controlled unit, set the knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp model). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you troubleshoot & solve the problem
Jul 04, 2011 | Haier HD308 Dehumidifier
My Whirlpool dehumidifier runs, but compressor does not come on.......we do have moisture in the basement because the basement recently had a water problem.....and typically the compressor would come on....
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Whirlpool Dehumidifiers
Unit not taking moisture out even tho the fan seems to be working
is compressor running fan maybe compressor must be running for dehum to take the compressor has a distint sound should be easy to tell by sound
Aug 21, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
My LG LHD45EL all of a sudden
Short on refrigerant... or a failed compressor. are most likely or a system problem, causing it to trip off.
There may also be a failed electrical component, you need to check for voltage at the compressor.
cheers
Jul 02, 2010 | LG LHD45EL Dehumidifier
Dehumidifier runs(fan & compressor)but pulls very little moisture out of humid basement. it was given to me & has been in use for about one season.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 11, 2010 | Haier 45-Pint Dehumidifier
A7DH45B2A Dehumidifier: Can anyone help me understand why my dehumidifier ...
The biggest reason is plugged filter...or te coil bhind the filter is plugged. Then you get into whether the compressor itself is running or not. Just because the fan is running does not mean the compressor is
May 10, 2010 | Fedders A7DH45B2A Dehumidifier
Kenmore 54501 turns on but nothing happens in my damp basement
A dehumidifier heats and cools the air to remove moisture. Most are like a small air cond. The Condenser coil is right in front of the evap.coil. So the compressor may not be coming on. Does it sound the same as before? It may be low on freon. You will have to get in there and listen and feel the lines at or near the compressor, Learn how to get down in there to the compressor. Run it for 10 Mins. unplug it, open it up, and feel the lines. Some lines should be or can be HOT to the touch. Some should be cool. The smaller the line the hotter it should be, and the compressor should be warm (to hot) to the touch. repost for more info.
Jul 08, 2009 | Kenmore 54501 Dehumidifier
LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Jul 02, 2008 | LG LD65EL Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Fedders A7DH65B2A Dehumidifier Logo
513 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
dadr
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
