Question about Brother MFC-8220 Fax
Feeder Paper only feed halfway then stop.
  • Brother Master
  • 1,113 Answers
Paper being printed or Sent? but prob Dirty feed roller (paper feed or doc feed roller)
Posted on Oct 12, 2007
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Scanner not feeding on lexmark x7170. paper feeds halfway in them reports error/clear paper jam in scanner document feeder.
    I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
    Nov 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
    Paper feeding problems Riso TR1510
    refix your ink cartrdige also check there is not any paepr jam issue.
    also some times printer neeed servicing creates this type of issue.
    Mar 28, 2009 | Riso Office Equipment & Supplies
    Lexmark x5435 paper feeder broken
    Feeder goes halfway down & stops on Lexmark #5270 & would like free answer
    Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
    When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
    SOLUTION(S): Reset the Sheet Feeder Gears
    If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
    alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
    home position, which may not be possible if the paper stop cam is not in the correct position.
    PROCEDURES
    1. Remove the sheet feeder from the unit.
    2. Remove the sheet feeder motor from the sheet feeder assembly.
    3. Remove the drive gear from its spindle.
    4. Realign the lifting tray gear and paper stop cam gear.
    5. Reinstall the drive gear and sheet feeder motor.
    6. Reattach the sheet feeder to the print unit.
    7. Reassemble the unit.
    Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
    Document feeder
    Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
    Oct 25, 2008 | Office Equipment & Supplies
    HP PSC 1610 All-in-One paper jam
    ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
    Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    The document feeder keeps trying to feed
    You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
    Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
    Brother MFC-8220 Fax Logo
    264 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
