Question about Toro& Electric String Trimmer
I cannot figure out how to get the spool off of 51346 weed eater
I have purchased a replacement spool and cannot get the old one off. help. someone. help i seem to recall buying a whole new unit the last time i had this problem
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
SOURCE: new weed eater 13" electric trimer, want to change the spool
Usually one get a a spool of the cutting wire and it snaps into place.
http://flymolawnmower.co.cc/reviews-Toro_Electric_Trimmer_Replacement_Spool_with_065_Inch_by_10_Foot_Line_88185-B00005V7KY.html
Shows you also how to do it on package.
Posted on May 29, 2010
  • 7 Answers
SOURCE: I have a Toro Electric weed eater and cannot get
Did you try using a flat screwdriver between the head and the bump knob?
Posted on Aug 17, 2010
2strokeguy
  • 183 Answers
SOURCE: My Toro 12" Trimmer (Weed eater) needs a new screw
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Posted on Oct 14, 2010
vincob
  • 718 Answers
SOURCE: How do I change the
Go [smalleng.com] they have videos on just what you need. Good Luck....
Posted on Mar 10, 2011
Ryobi weed eater troubleshooting
Here is a video I found helpful.
https://www.youtube.com/watch?v=iMFUW6DJia0
Aug 19, 2014 | Garden
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Need to replace the wirefeed? Purchased 8" orange
Hi gramcherry1...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
How to replace string on te475y
Hi jtl91370...
Try this solution...
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
SPOOL HOLDER IS BROKEN AND NEEDS REPLACED I WANT TO PURCHASE REPLACEMENT PART
I'm taking a guess here. Are we talking about a weed eater?
If so, most home improvement stores with a garden department have a section dedicated to replacement spools and accessories.
Normally the make, model and type of device are quite useful in the diagnostic process.
Mike
Jun 21, 2011 | Garden
Poulan PL 25 plastic cord replacement
You can buy bulk cord of the correct size and re wrap the old spool. Or, go to walmart and buy pre-wrapped spools.
Mar 15, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I just bought a craftsman weed eater and the fishing line gets caught up and wrapped around the spoke of the turning mechanism in between the the covered spool and the machine. How can this be fixed. Is...
it is very hard to rewrap the line in any weed eater. Techs get paid good money to do this, and there is a spring that must be placed inside the spool container that gets pressed to release new line. My suggestion, if is giving you this much trouble, and, will every time it needs new line. remove your old spool and go to the hardware store and purchase a spool that has plastic or metal blades on it. ie, no line, nothing to wrap, nothing to feed. Just be careful using it and do not let a child near it, it will nick you. They are less than 20 bucks and alot cheaper than getting a technician every time it needs to be rewound. I worked for sears and we saw these every day. If you must have the line. follow the steps in the manual step by step, it does take some force to get the spool back on properly, because of the spring. just make sure you direct the recoil away from you or your body at all times.
Jun 11, 2009 | Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Weed eater spool fell off
the spool goes on first then a big spring and finally the cap and the screw thats all
May 24, 2009 | Garden
Toro& Electric String Trimmer Logo
394 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
