Question about Back to Basics BPE3 Blender Express 2 Speed Blender
Base with blades and gasket are stuck to the blender pitcher. How do I loosen it. I have tried soaking the whole unit and also pouring hour water into the pitcher. Nothing seems to be working
  • 79 Answers
SOURCE: Waring Pro MBB Blender- blade too tight
If you can get the shaft out of its bearing, you can clean the shaft with steel wool. You may also have to scrape the inside of the bearing with a small rat-tail file.
Put some vegetable oil on the shaft and reassemble.
DO NOT USE WD-40 OR 3-IN-1 OIL! This mechanism will be in contact with food/beverages, so you want a lubricant that is safe for human consumption.
If the problem continues to occur, I would buy a replacement. In some models, this means buying a whole pitcher assembly.
Posted on Mar 15, 2008
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: The lid/blender blades is stuck on to the jar.
Apply vinegar to a rag and a couple of q-tips - use the rag for any exposed areas, and use the q-tips to let vinegar drop into the hard-to-reach areas. You tried everything else I would have suggested.
If all else fails, break any of the parts on this list an reorder them :-) :
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3659&linkon=subsection&linkid=120&secid=53
-Tha Mp3 doctor
Posted on Mar 25, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Replace the glass pitcher for the Margaritaville blender
Replacement pitchers here:
http://www.margaritavillecargo.com/Accessories.aspx
-Tha Mp3 Doctor
Posted on Mar 31, 2009
SOURCE: Blade won't turn in Cuisinart Duo Blender -- not motor
Thanks for the suggestion about loosening in the opposite direction. We didn't completely take our blade apart, but loosening it a bit seemed to help. We worked the screw around then tightened it back up and it worked great.
Posted on Jul 06, 2010
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
Hi. We have a Cuisinart smart power blender. When we mix drinks, there is some sort of black residue seeping into the glass pitcher. Do you know what is causing that?
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Jul 14, 2011 | Cuisinart Blenders
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
I accidently poured milk into the glass pitcher when the bottom blade/cap was not on! it went thru the motor unit... I am trying to dry it - what to do? let it completely dry over some hours before trying...
I think that you need to flush the unit with water, I would take it apart, then let it dry COMPLETELY before plugging it in....I suspect that the unit will not be damaged.
Mar 04, 2011 | Breville BBL550XL 5-Speed Blender
My 5 speed KSBS kitchenaid blender is stuck together (glass and underneath part that would fit into motor base.
Have a look at the pictures here.
I think you are describing the blade unit's gasket being stuck. This can happen over time and especially if bits of food get stuck and harden. Try soaking for a long time in warm soapy water then keeping applying pressure until the seal between the gasket and jar gives.
Feb 12, 2011 | KitchenAid KSB560 5 Speed Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Dec 28, 2007 | Waring BB180 Work Top Blender
Hamilton Beach 52184 12 Speed Blender
keep trying it will loose unless it had worn out then you will have to replace the blade.
Apr 08, 2007 | Hamilton Beach 52184 12 Speed Blender
Back to Basics BPE3 Blender Express 2 Speed Blender Logo
129 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
