Question about HP G60-230US Notebook
My wireless light on my hp g6000 notebook stays orange when switched on instead of going blue.And the wireless won't work Seems like a habitual problem with HP G60... just purchased one and wireless button stays amber, won't turn blue when I push the button. No wireless device detected in system. Guess it's back to Best Buy!
    New Friend:
This is a very frustrating problem. It is not firmware, software, bios or the hardware you'd expect. I had the same problem with mine and I eventually came across a casual comment on a site complaining about the button itself.
I discovered that if I carefully pushed the button using my thumbnail on the edges, just enough to feel or hear a click. It wasn't the same part of the button consistently but once I discovered the finesse required to make it work it worked consistently.
Posted on Oct 13, 2013
  • Ladybug Mar 07, 2014
    Also Try Windows Key Plus X - that sometimes allows access to the windows mobility centre (which is also accessible through Control Panel . )
I had that same problem, I turns out about a day later I dropped the laptop on accident and it started working again. I would not advise my way of getting the button to work again.
Posted on May 09, 2009
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
My wireless assistant has stopped working and the light stays orange
I had the exact same problem...and the wireless adapter was not visible under device manager. The light stayed orange with the switch in either the on or off position. I did all the whole driver update thing and eventually replaced the wireless adapter but no change. Finally I went into the BIOS (F10 on startup) and reset the bios configuration to the default settings EXIT>LOAD SETUP DEFAULTS). It has worked perfectly ever since.
Sep 03, 2010 | HP Compaq Presario F500 F700 and G6000...
Wireless device switch not working, stays orange and not blue
you probably got a nvidia chip set and that chip is going bad on your motherboard. it's pretty common failure on the 443875-001 hp/compaq motherboards. Sometimes letting the laptop cool down the wifi will come back; but it will go out again!
A usb wifi card should solve this problem; otherwise you'll have to replace the motherboard ($150 + labor).
Aug 16, 2010 | HP Compaq Presario F500 F700 and G6000...
My compaq laptop cannot find any wireless and the
Can you describe what software/program you are using to establish the wireless connection? What colour Led is located near the wireless button? Ornage of Blue? It should switch from orange to blue, if it stays orange, the Wireless card is broken. This is a known issue on all HP DV6xxx, DV9xxx but also on allmost all Compaq V6xxx units. And has extended warranty, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN kr Gijs
Sep 10, 2009 | HP Compaq Presario F500 F700 and G6000...
My hp pavilion entertainment pc is showing orange for the wireless connection.. when I click on it, it doesn't turn blue it just says WLAN: on or WLAN: disabled but even when it says its on it stays orange...
1. Go to device manager ad check your wireless card is not diabled,
2. Try to search your network and see if your laptop could detect it
3. you can try Fn + f2 kesy as well to turn off/on your wireless switch,
Jul 27, 2009 | HP Pavilion dv7-1132nr Notebook PC
Wireless not working
Did you disable the wireless card through the BIOS? Sometimes the wireless card can be accidentally turned off through one of the HP Wireless Assistant which will keep it from turning Blue when you press it
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Wireless problem with laptop, HP DV9000
Follow the link below, read about this problem, and then call the special HP phone number. They are repairing these computers under a special enhanced warranty policy, even if the regular warranty is expired. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Dec 27, 2008 | HP Pavilion dv9000z Notebook
My only solution was to send my laptop back to HP for repair - turns out the light means that the on board wireless has failed
Aug 24, 2008 | Computers & Internet
HP G60-230US Notebook Logo
791 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
