Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rannai function lock
I am renting a house and have a rannai 1004f monitor heater, my son dropped water on the control panel and now the system is saying function lock....Is there anything I can do to fix this myself?
Thanks Kerry
  • 1,420 Answers
Have you tryed unlocking it by holding down on the lock button for 5-6 seconds?
Posted on Oct 12, 2007
SOURCE:
Cant light my heater rannai reh 18 p
I would suspect the gas valve is defective.
Dec 08, 2016 | Heating & Cooling
What kind of propane regulator do I need for my RL 94 rannai?
That is a water heater or boiler? You need to contact a gas service contractor. It would be dangerous to do it any other way as the gas pressure needs setting.
May 03, 2016 | Grilling
My rannai propane heater makes a whistling sound.
Check the fan. Unplug the unit and remove the panel that houses the fan unit. Electrical cleaner can be sprayed onto the connection points of the nicad heater elements as well as the fan motor. It may be that one of the heating coils has a bad connection. Take apart and reassemble heating elements and connection points.
Jan 17, 2015 | Heating & Cooling
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 29, 2012 | Water Heaters
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
Can a Rannai RCE329A vent free wall unit be vented?
Sorry, no. The UL rating of this unit specifies "Unvented Installation Only".
Jan 18, 2010 | Rinnai Vent Free Gas Heater/
Rannai 2520
This is a water heater not a heater, sorry. Remove the ignition probe just below a small window and adjusst the gap after polishing the probes. Make sure all wires are connected good. Test fire unit.
Dec 19, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Control panel not working after "function lock" buttons pressed
MD,
Hit the up and down again and do away with the Function Lock.
Tom
Apr 23, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Is there alot of problems with bosch aquastar 2400
Bosch has had problems with these heaters for sure. They are the best known thing out there in the market.They are mostly responsible for the bad rap being given to all tankless heaters, but a big part of the problem is installation. They are being sold to homeowners at box stores as DIY kits. These are not units to be homeowner installed, venting and fuel requirements are different from regular heaters and they will not function correctly if improperly installed. I have installed several of the Rannai units over the past few years without any issue whatsoever.
Mar 10, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Blow off periodically releases small amt of water.
This may be the case. If you have a check valve installed on the heater to prevent the hot water from backing up into the inlet or cold water side this may happen. A hot water expansion tank at the heater or water hammer devices near the fixture itself should cure the problem.
One question, how high is you water pressure?
Dec 01, 2008 | Rinnai Webstone The isolator EXP tankless...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
361 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
