Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Will not crank
The belt to the transmission came off. I removed the deck and put the belt back on. Now the engine will does not seem to be getting power from the battery. is there some osha switch that I need to reset?
  • 1 more comment
  • davidhey May 10, 2009
    I can't find either of these switches
  • davidhey May 11, 2009
    Its a DYS 4500, 24HP V Intek, 42" deck
  • Daddyshlov May 20, 2009
    How to replace transmission belt on a lawn riding mower? Bolens, 38". I wish to know step-by-step.
    President:
  • 2,559 Answers
There is a switch under the break that needs to be pushed and a safety switch under the seat that must be pushed.
Posted on May 09, 2009
  • Randy Hough
    Randy Hough May 10, 2009
    Give me a model # and I will get the location of all of the for you.
How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
May 11, 2017 | Garden
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
I need a schematic for installing a cub cadet LT1050 drive belt. The old belt broke and I'm just not sure how to replace it. It appears you need to remove the clutch for the mower blade firat.
To replace a transmission drive belt on a Cub Cadet LT1045 or LT 1050 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO.
The PTO may be sized on there so you may want to tap it with a hammer and a block of wood carefully to release it. AT this point remove the 4 engine mount bolts from underneath (1/2" I believe). You will need to remove the left steering nut and arm to have access to the 4th bolt. Do not remove or replace engine mount bolts with impact wrench or bolts may break. Loosen old belt from tensioner pulley. Place pry bar under engine to slightly lift engine and move aft to expose belt from pulley and remove from pulley. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Carefully push engine back into place and exhaust pipes into forward muffler will take some patience. Bolt engine back on being careful not to over tighten bolts. Place steering arm and nut back in place. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
Aug 16, 2014 | Cub Cadet Garden
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How to replace the top belt that goes to engine from transmission on troy bilt model LTX-1842
Unfortunately there is no easy way to do that.I find that removing the seat and rear fenders is the best way to get at the engine pulley.I remove the deck and the deck belt then drop the belt from the engine to the front.Make sure to get the belt inside the tension pulley before you put it on the front pulley.You will need a small pry bar or large screw driver to get the belt on the last pulley.Before you use one of those wrap it in an old rag or some leather(old belts work)to keep from damaging the belt.I would suggest replacing the deck belt while you are down there,I always change both as it is not much fun to change the belts.
Thanks for using Fix Ya.
Jun 11, 2011 | Garden
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Change front main seal , leaking oil around timing chain cover. could be seal around harmonica balancer.
yes, I just changed one of these recently. Had to take both front and bottom off engine. Very difficult repair, as there are no good jack points for the engine when you have all the motor mounts off.
Here is procedure I would recommend.
Remove starter and engine to transmission brackets front and back.
Remove transmission starter gear cover.
drain oil and remove oil pan.
put a block under the crankshaft and jack to release weight on motor mount.
remove front motor mount (by serpentine belt)
remove belt.
remove compressor and bracket.
remove crank pulley and vib damper.
remove timing cover. mark timing belt with direction of travel
loosen tensioner gear.
remove timing belt.
remove crankshaft timing gear and key.
remove seal and oil pump housing.
clean gasket surfaces.
replace seal and reverse procedure.
If you have questions, let me know.
Oct 06, 2010 | 1993 Dodge Caravan
How to put on drive belt onmy mower
Based on experience with MTD and AYP products: 1) remove mower to deck belt, 2) remove deck, 3) have helper press brake pedal down which puts slack in drive belt, 4) pull drive belt first from front engine pulley or rear transmission pulley then remove entirely. Reinstall in reverse order.
CAVEATS 1) If a pulley is grooved then the narrow part of the belt goes into it, if the pulley is flat then most likely the back of the belt goes against it in a tensioning function. 2) There are often guides or keepers which hold the belt in place, these can be hard to see and if the belt is not routed inside them it may well not work or hop out under load.
Jun 30, 2010 | Craftsman Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
158 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
