Question about Equinox ELS 16 Terminal Server
Setting up an ELS 16 Terminal Server
Trying to set up a replacement server to commuincate with a remote host.
We have been working with Avocent, but still unsuccessful
Re: Setting up an ELS 16 Terminal Server
Have you tried this?
DEFINE NODE GATE1 IP (enter gateway ip here) GATEWAY ENABLE
Step 2.
Posted on Nov 27, 2008
0 characters
3 Points
I have a problem, i try to access the Avocent ts100 by hyperterminal in winXp, I used a usb to db9 cable but it didn't access to first page or menu, the hyperterminal configuration is 8n1n, only show...
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. report.gif digg.gifdelicious.giftechnorati.giffacebook.giftwitter.pngstumbleit.gif quote.gif
Jul 13, 2011 | Avocent Cyclades TS100 (TES0061001)
I can't access my web site
Hi,Problem is an possible one, You find reason for website problem and solve it,may problem in hosting or connection,I have an good hosting with this site ,still now there is no problem for me.
Mar 22, 2010 | HP Web Hosting Server Appliances SA1100...
Access server manager 3.6
The DECserver 732 is a high-density, high-performance asynchronous device and remote access server that provides 32 MJ8 (RJ45) serial ports. The DECserver 732's serial ports support either of two sets of software-selectable four-signal modem control signals. The DECserver 732 has AUI and 10BaseT Ethernet connectors. The DECserver 700-16 supports up to eight sessions per port and speeds up to 115.2 Kb/s per port. The DECserver 732 has an external FLASH socket for the customer-installable flashcard. When installed, the flashcard allows self-booting operation. The DECserver 732 runs DECserver Network Access Software (DNAS), which delivers multi-protocol support for TCP/IP, IPX, and AppleTalk networks. DECserver 700 units are designed for tabletop or rackmount configuration
the u need to check these site for more info:
Jan 05, 2010 | Digital Products Digital DECserver 732...
Hi, I can not telnet the terminal server ip adress from oss ,but i can ping it how to telnet it?
Open <IP Address> <port number>
this way you will know if telnet is working or not as well as whether the connection is being permitted
Port number may not be required depends on your set up
Oct 04, 2009 | Cyclades AlterPath ACS-16 (ATP0050)...
Host unreachable
Is it mapped on the pc you are trying?
Aug 10, 2009 | Other Network Devices
Want to add a network printer.
Where is your restaurant? Give me your phone # and I can help.
May 02, 2009 | Other Network Devices
Enable LAT protocol on Shiva Atom?
Since the only thing that changed was the Shiva Atom, I'm guessing that the license error is coming from the terminal server itself rather than the VAX, corrrect? My only suggestion would be to replace the ethernet chip on the new server with the one from the old server. Perhaps the license is tied to that address. It should be a small 8 pin IC in a socket. At the time of these units being built, the Ethernet ID chips were usually installed in sockets.
Hope this helps,
Apr 30, 2009 | Intel ShivaPort Atom (SATOM16TX) Terminal...
Laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
Jan 17, 2008 | Other Network Devices
Equinox ELS 16 Terminal Server Logo
386 people viewed this question
Top Equinox Other Network Devices Experts
 C. Dante
C. Dante
Are you an Equinox Other Network Device Expert? Answer questions, earn points and help others
