Banging noise on spin cycle
When our washing machine is on the spin cycle it sounds like the springs that hold the drum in place have become slack allowing the drum to swing back and forward knocking against something?
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
Posted on Feb 01, 2010
I have just moved my asks w 6551 to a new house and now it's making a banging sound when the drum turns. Is this serious?
Those machines come with shipping bolts that hold the drum to the frame when it is shipped. This ensures that nothing gets slammed around when it is moved. Without those in place, there is a chance that the shock absorbers and springs that align the drum when it is on CAN COME loose and then you have a banging noise when the drum spins.
Oct 22, 2017 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
When spin cycle stops the agitator stops but the tub spins and makes a loud banging sound
it sounds as if one of your springs has broken or become detatched from the outside of the drum. open the top cover and have a look. ensure the power is switched off.
thanks iain
Apr 28, 2011 | Kenmore Washing Machines
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
I have Kenmore 60 series large capactity washing
There are two or three springs that hold the drum upright and level. They are attached to the motor and the drum base or sides. You have a broken spring. From being overloaded or turning during a last spin cycle it was out of balance and broke a spring. The machine will have to be taken apart to expose the springs. They are about 4-6" long. If the mounts are Ok replace all springs.
Oct 17, 2009 | Washing Machines
Model #fwtr647ghs- It washes fine bu there is a clunking sound that happens on spin cycle, like somthing is being hit
Hi I am Vortash the most likely cause of your impact sounds are the drum as it hits the side of the machine on spin .. this is a result of an uneven load and the fact that the suspension springs for the drum and support rubbers may be worn . The load evens itself out eventually and the banging stops I assume , as the centralfugal force evens the load and the drum spin becomes more balanced . Replacement or tightening of the springs is adviseable but it depend how old the machine is as to the economics of this .. regards Vortash
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
471 people viewed this question
Top Washing Machines Experts
