Question about Sharp Office Equipment & Supplies
AR -208 N Needs starter and drum replaced. Need
AR -208 N Needs starter and drum replaced. Need access to service mode.
    Guru:
  • 389 Answers
For given repair will take:
Fotobaraban AR-202DM.
Pliers
The Vacuum cleaner for peelings of the node removable unit containing and corona.
To take the block of the drum out of copier it is necessary,disconnect feeding,open shift to the right lid,on she is found corona carrying,open the front lid,take out the toner-cartrige,take out the block with developer and finally take out block itself with drum.
The Bonanza block before itself.With pliers we roll the dowel,which keeps the drum and take out him(it).
We Remove drum.
The Vacuum cleaner net corona and removable unit containing .
We Put new фотобарабан,insert and twist the dowel.
We Insert the block of the drum on place,then block with developer and toner-cartrige.We Close shift to the right door,include the device.
Posted on Sep 13, 2009
Copier flash maintainance call
Needs the drum, drum blade, developer replaced and a good interior and exterior cleaning. Call a service center to get service.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have replaced my drum cartridge on my sharp copier, however, the drum indicator light remains on. How do I get the light to go off?
I am not sure about the 208 but try this procedure I have posted here on Fixya. I beleive it may work for you. It sure won't hurt to try.
To reset the drum light on just about any Sharp AL or AR series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Oct 14, 2010 | Sharp AR-208S Black and White Copier
The machine is showing service man and developer
That means that the drum & developer needs to be replaced. It depends on you? You will also need to reset the counters. Also, you can turn those warnings off in service mode.
Sep 15, 2010 | Sharp AR-M205 Copier
I have a Sharp copier AR 250 and getting service code F2-31
this code refers to the drum....the copier is unable to create a patch on the drum that is satisfactory erplacement of the drum is needed the developer starter powder should be changed at the same time service technician required
Mar 02, 2010 | Sharp Office Equipment & Supplies
How do you replace the drum on a sharp ar m208n
just remove the old one and insert new
Nov 11, 2009 | Sharp AR-M208N Copier
Need to replace drum on photocopier.
You need a cleaning blade too. and after installation, you need to calibrate it within service mode. This should be done by a technician
Mar 16, 2009 | Sharp AR-M208 All-In-One Laser Printer
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
176 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
