Question about Pioneer PRO-530HDi 53" Rear Projection Television
I have a sony color rear projector t.v model KP-57WS515. It wont power on, It blinks 6 times.It does this every time
  • 60 Answers
Hi Chris,
You might check out the posting I made with the same symptoms.
-Dan
http://www.fixya.com/support/t1008420-sony_kp_51hw40_6_blinks
Posted on May 09, 2009
SONY KP-61HS20 DOESN'T COME ON JUST BLINK 6 TIMES PAUSE AND 6 TIMES AGAIN
Sis blinks of standby light denotes No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. If you wish to get more details about blinking codes to Sony PTV, check this link.
Mar 03, 2013 | Sony KP-57HW40 57" Rear Projection...
My jan 2002 sony color rear vidoe projector kp-51hw40 keeps turning off scc-p65g-a
When it turns off does the indicator blink? if so how many times does it blink?
Jun 14, 2011 | Sony KP-51HW40 51" Rear Projection...
Model kp-53xbr4ct made 1998. picture was good. sudden went to center of screen and bowed up and down from center. it hade sound. turned of, now no sound. stand by flashes 6 times. unplugged , plugged back...
the video color distortion with the bowing in the center is called a convergence failure. the 6 blinks indicate a power supply shutdown for high voltage protect. the 14 blinks is just the tv trying to turn back on. you may be having to problems with the convergence and the 6 blinks or it may be related because the convergence amps can cause shutdown if they are shorted. i suggest calling a serviceman per the possible tow different failures. good luck
Jan 12, 2011 | Sony KP-51HW40 51" Rear Projection...
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
TV wont turn on
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Aug 20, 2008 | Sony KP-41T65 41" Rear Projection...
Sony kp-51ws520 blinks 6 times
Heres what the 6 blinks means with your model. Here is a link where you can gey the full service manual for your set with trouble shooting and full part number list. they email them Instantly after purchase
• +5 line is overloaded.
(A and BM Boards)
• +5 line is shorted. (A and BM Boards)
• IC303 is faulty. (A Board)
Heres the link for the manual
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Pioneer PRO-530HDi 53" Rear Projection Television Logo
48 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
