Question about NEC PlasmaSync 50MP1 50 in. Television
Nec plasma I have sound but no picture
What should the input and output settings be set at
what is the difference between RGB 1, 2, 3, or video, dvd/hd settings, I have no manual and do not know what to set to get picdture.  HELp
  • 661 Answers
Here is the manual
http://www.de.nec.de/software/816_50MP1_eng.pdf
enjoy
Posted on Oct 11, 2007
SOURCE:
NEC PX-50XM4A 50" plasma tv - I get a picture but no sound. I have my cable box plugged in to the DVI port converted to HDMI going to my cable box but I cant get sound when I plug external speakers in to...
HDMI carries both video and audio.
Do you get video and audio on TV. Just to be sure.
Now are the external speakers powered ?
are you connecting the Speakers to Audio Out of the TV ?
By the way, I cannot see any RCA port that is output port on your NEC plasma. NEC 50XM4 User Manual Specifications The audio input is for audio from dvd for example.
Oct 23, 2013 | NEC Televison & Video
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
I have pictures on the screen but no sound. I have connected 8ohm speakers. Would this be a problem?
no this would work fine but do not use high volume for long periouds Check youre settings as you may have the wrong rgb sound input set try diverent sound inputs double check that ther is sound on the input lead hope this helped
May 29, 2010 | NEC PlasmaSync 42MP2 42 in. Television
I have a NEC plasmasync 4205w monitor PX 42M4G wit no sound.
just re-install the drivers from the cd tat came wit the monitor... or download it from the vendors website... Also set the sound settings to Normal or Room k... take care...
Sep 21, 2009 | Computers & Internet
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Connecting dvd?
If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
Jul 01, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Acoustic solution lcd tv
This sounds like the unit is expecting component video input (RGB) rather than composite (yel). Check the settings on the set. The power cord makes no difference.
Keep us posted.
Dan
May 20, 2008 | Televison & Video
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
NEC PlasmaSync 50MP1 50 in. Television Logo
200 people viewed this question
Top NEC Televison & Video Experts
Ekse
Kyle Steven OHare
Kyle Steven OHare
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
