Question about IBM ThinkPad T22 2647 Notebook
I have an IBM Thinkpad T22. I need a master password.
The laptop will not boot until I put a password to unlock the computer itself.
Ibm t22 thinkpad(PXE-E05 LAN ADAPTOR CONFIG.- OR NON STARTED or CORRUPTED. BOOT AGENT CANT CONTINUE
On line search should give you a manual, almost all are available, simple search and you are done.
May 06, 2012 | IBM ThinkPad T22 2647 Notebook
I have forgotten my BIOS password for my T22 Laptop IBM.
To reset the BIOS password on your IBM laptop read the information from this link.
Apr 09, 2011 | IBM Thinkpad T22 Notebook
I forget my Laptop Startup password of IBM T60.
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Jan 17, 2010 | IBM Lenovo ThinkPad T60
I just got a thinkpad t22 900 mhz that seems to have a bios lock on it. How do I fix that?
The BIOS password is configured from the BIOS setup and this password is stored on an EEPROM chip. There is no backdoor password available and IBM/Lenevo support say the motherboard needs to be replaced. Also removing the BIOS battery to discharge the BIOS and reset it to the default settings will not allow you to bypass this password.
There is a way to crack the password but you need electronic skills, electronic components and several programs plus a working computer to carry out this task.
For details on how to do this check this WEB site.
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Oct 07, 2009 | IBM ThinkPad T22 Laptop
Ibm x31 password problem
Visit: http://www.ja.axxs.net/unlock/
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Power on the computer by pressing and holding F1.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click on the Password icon.
  4. Click on the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click on Exit; then click on Restart.
Jun 19, 2009 | IBM ThinkPad X31 2672 Notebook
Thinkpad T22 semi-working DVDROM
have you tried cleaning the lens ?
Mar 02, 2009 | IBM ThinkPad T22 Laptop
Forgot startup password
For the Windows password you will need to reformat your hard drive. If that would not be done or if there is another way of removing the password without removing and reinstalling the operating system or of using your laptop by working around, windows password does not make sense at all. Hope this helps. Thank you.
Oct 01, 2008 | IBM ThinkPad T22 2647 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
735 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
