Can't recharge A/C system
Where is the low side a/c connector on a 2004 PT Cruiser. Does not seem to be in place indicated on Haynes manual for 03 PT.
  • 116 Answers
Not sure however if you follow the big line from the compressor to the firewall you will find it clean the coil on the raidiator with mild cleaner before chargeing to keep head psi low this may be its problem and rember whare it is leaking from their should be a sign of oil and dirt collecting
Posted on May 10, 2009
    President:
  • 710 Answers
IF I REMEMBER CORRECTLY IT IS JUST ABOVE THE FAN SHROUD. VERY TIGHT FIT. GOOD LUCK. THANKS IN ADVANCE FOR AN HONEST RATING. KEEP ME POSTED.
Posted on May 09, 2009
  • Mark L. Roberts Jr.
    Mark L. Roberts Jr. May 09, 2009
    JUST ABOVE THE COOLING FAN. HOPE THIS HELPS. LET ME KNOW. THANKS IN ADVANCE FOR AN HONEST RATING. AND THANK YOU FOR USING FIX-YA
Removing 2003 pt cruiser driver side quarter window i need to know how to remove trim around quarter window to access the bolt holding window in place
If you pick up either a Chilton or Haynes manual for Chrysler PT Cruiser 2001 -2010 it has some very good instructions and photos
Feb 17, 2017 | 2003 Chrysler PT Cruiser
I have an 08 PT Cruiser since new ,now 50,000 miles the air conditioning quit. only hot air. I'm at a loss. Don't know where to start checking.any help appreciated. Thanks
While the vehicle is idling with the hood open and the AC set to Maximum cool listen for the AC compressor to kick in. If it is kicking in frequently, you will be able to tell the difference, then you need to recharge the system. This is a periodic requirement and doesn't necessarily indicate a major problem. You can get a can with a gauge to refill the system from any of a number of places. I usually use Arctic Freeze R134a. The directions are on the can and the fitting will only connect to the low side of the system so you don't have to worry about making an error by connecting to the high side by mistake. Add freon till your system is in the proper operating range and the compressor stays operating while the AC is on. Now, if you connect to the system and the reading is too high you have a serious issue and will need to have the whole system serviced by a shop.
Jul 05, 2011 | 2004 Chrysler PT Cruiser
I'm trying to recharge the A/C in my 04 PT Cruiser. I can't seem to find an accurate answer to which hose is the low and which is the high side. I have a large diameter hose and a small diameter hose. The...
The low side connectors are diffrent from the high side, you would not be able to connect it anyways. The high side has a bigger port that the low side, and it would not fit anyways.
Aug 04, 2009 | 2006 Chrysler PT Cruiser
My pt cruiser air conditioner will not cool. I
Go to low side fitting. Usually the larger diameter hose & tubing, is low side.
Jul 16, 2009 | 2004 Chrysler PT Cruiser
I have a 2002 pt cruiser and my ac is not colling
Your car ls most likely low on refrigerant. If you're handy, you can get a recharge kit at an auto parts store to recharge your AC system. If not, most service stations will recharge the system for under $100 but be aware that they are mandated by law to detect any leaks prior to recharging the system. If a leak is detected, they must repair the leak prior to recharge which would lead to a more expensive repair. Best of luck.
Greg
Jul 07, 2009 | 2002 Chrysler PT Cruiser
My 03 pt cruiser won't ignite or crank all lights work even tried jump starting it and it wouldn't even crank
How is the oil pressure or low oil. Did the car over heat is so you may have to replace the oil pressure sensor.
Jun 24, 2009 | 2004 Chrysler PT Cruiser
2004 chrysler pt cruiser with only 25k miles and i got a codes po300 and po301 misfires any help?
Good place to start, but If you check directly with Chrysler there may be a technical service bulletin, that isn't posted yet. Have the codes cleared when work done, and see what happens.
Mar 01, 2009 | 2006 Chrysler PT Cruiser
Replace radiator can find 2002 PT cruiser woodie manual
get a Haynes Manual for your car from auto zone or advance auto.You will have to take off the front grill and it sets in your face. The Haynes Manual will show you step by step how to fix your problem........runjoe
Feb 24, 2009 | 2002 Chrysler PT Cruiser
Heating & Cooling Logo
315 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
