Question about Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive
I have a Beyond Micro MobileDisk 300GB 5400/2MB Ext HDD. My Dell Inspiron 1721 laptop with Window Vista won't recognize this external hard drive. Is there a new driver to download or some other way to fix this? The green light is on on the front of the external hard drive but I don't find it on my computer.
  • Anonymous May 21, 2009
    I have the same problem but I have a mac and I do not know what I should do?
  • 413 Answers
I am giving you magic out of my pendora box..........
As your system has got infection so booting it normally actually wont help you much so kindly boot your system in safemode with networking and download following
1.Malawarebytes.exe
2.Trojan Remover.exe
And
3Combofix
Now update it and run them one by one in sequence ,This will free your system from any harmfull infection may it be ,you ve mentioned that you are not able to open the pen drive it is because of trojan so keep your removable media plugged and then after finishing operation in safe mode run the same in normal mode
Now these steps not omly fixes the problem but makes your pc 20-30 times fast depending upon configuration as ypur sytem performace will be automatically optimized and prevent and future intrusion
First things first .....check for power cable and data cable and make sure they are not tampered or damaged now move to next step>>>
kindly remove all jumpers in HDD now go to
Control panel>Administrative tool>Computer management>Disk management
you can see the disk here and change settings accordingly like assigning path and drive letter if this does not work
then just see that is it recognized in device manager as unrecognized device then update driver for HDD even now if the problem persists
KIndly consult the manufacturer
One more thing you asked about drivers let me inform you that OS Drivers natively supports this
device
Thanks And Regards
Posted on May 13, 2009
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
My dell inspiron 1721 is stuck on start up. The screen with ctrl + F to enter build utility. Ive tried to reinstall vista but on the install. I get stuck on the load drivers screen. I have the drivers on...
Hi, first of all have you tried to run the diagnostics just to ensure the hardware functionality of your computer? if not, here's how: As the computer boots, press when the Dell Splash Screen appears. When the Boot menu appears, highlight the Boot to Utility Partitionoption, or the Diagnostics option and then press to start the 32-bit Dell Diagnostics. Press the key to highlight Test System Press to continue to 32-bit Diagnostics. Note: Express Test is the only test that will not require user involvement.
If there's no error found, that means, that your hardware most esp the hard drive (HDD) that came with your system is perfectly working fine and this isolated your issue that it's the operating system problem. It's good to know that you attempted to rebuild the OS just make sure it's the recovery cd that came with the computer. try to boot from the OS cd once again and reload / reinstall Vista. Here's the link for your reference (see step 4): http://support.dell.com/support/topics/global.aspx/support/kcs/document?&docid=DSN_339949&isLegacy=true#Issue4
Apr 23, 2011 | Dell Inspiron 1721 Notebook
Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
Nov 04, 2009 | Dell Inspiron 1721 Notebook
Cannot get dell inspirion 1721 to find hard drive on system restore
Try restarting, and pressing f2 to access the bios, and making sure the bios is recognizing the hard drive..
If it is not, you will need to flash the bios for your machine..
Oct 29, 2009 | Dell Inspiron 1721 Notebook
I cant get the dell vista os reestore disk to boot up
Use external USB CD/DVD Drive to run your Windows Vista Operating System to Restore Disk.
Maybe your Built-in CD/DVD cannot read or access your OS.
If you don't have this device, you try another Windows Vista OS Disc.
Sep 15, 2009 | Dell Inspiron 1721 Notebook
Computer does not recongnize connection
External is damanged or you have problem with USB drivers...
May 10, 2009 | Beyond Micro MobileDisk 500GB 3.5 External...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Beyond Micro (BM120MD3U2) 120 GB USB 2.0 Hard Drive Logo
260 people viewed this question
Top Beyond Micro Computers & Internet Experts
David Payne
David Payne
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
