Question about Toshiba Satellite 5205-S705 Notebook
Internal wireless card is not working
The wireless part is not working but when hooked up by a cable i get the internet. any ideas?
    President:
  • 2,559 Answers
Could be the wireless radio is turned off.
Posted on May 09, 2009
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
How do I hook my wireless usb netopia chip in order to sign on the internet
You ned to contact an Internet Service Provider to determine if your USB wireless adapter is compatible with their service.
Read this info for an idea on how to connect to the Internet :-
There several ways to connect to the Internet.
1. You can use a cable or DSL modem and connect this modem to the laptop with a LAN cable.
2. You can use a wireless router with a cable or DSL modem and connect to the wireless router using a wireless card (a PCMCIA wireless card or the laptop may have a built-in wireless card). This wireless card can also be used in WiFi locations such as the airport, McDonalds and Starbucks etc.
3. You can use an USB G3 wireless adapter. This type of device uses the G3 mobile network and may not give you Internet coverage in some locations.
All these require an Internet Service Provider and the costs vary widely depending upon the various plans they offer. Check the ISP in your area and compare the plans and cost of their plans and pick the one that best suits your needs.
Sep 11, 2009 | Computers & Internet
Cant hook up my wireless internet card to my wireless g router
you can connect your huawei card to your computer usb port then install driver then you can use it.
Jul 28, 2009 | Linksys Wireless-G Broadband Router
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can't get it to work
I had the wireless working with dynex card before the virus hit the computer. The virus is fixed, but the internet does not work.
Feb 28, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Wireless Problems!
The computer looks for the cable because wireless is not working.
If wireless card is usb try removing laptop battery, unplugging power adapter and wifi cards, connect in five minutes and see if it works
If it still does not work, reinstall wireless card drivers.
If you have a disk reinstall them from disk.
If you lost the disk download drivers from the Internet, post model on fixya to get the link.
If the wireless card does not work after reinstalling drivers then it is probably faulty.
Note: if you use laptop internal wireless, usually you need to activate a switch to get it working.
Sep 13, 2008 | Computers & Internet
Wireless Problems!
Sep 13, 2008 | Balance A535 notebook 14.1 LCD Hinges...
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Toshiba Satellite 5205-S705 Notebook Logo
173 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
