Question about KitchenAid KESC307 Electric Kitchen Range
Finding a replacement night light bulb for kitchenaid superba
  • chrisandc190 May 09, 2009
    It is the night/surface bulb at the back of the range
    I was able to find the right part. Thanks so much
  • 718 Answers
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
Posted on May 09, 2009
Error code F2E4 On model KESC307 Kitchenaid Superba?
Tech sheet doesn't say much says noise interference at keypad says press cancel button and remove electronic noise interference if code returns replace key pad assembly not a common code if you chose to replace the keypad make sure it comes with instructions have changed two has to be programmed
Feb 14, 2015 | KitchenAid KESC307 Electric Kitchen Range
KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
How do I replace the oven temperature sensor/thermal fuse in my Kitchaid oven?
Unplug the range.
Open the oven and look on the top left back wall of the oven to see the sensor protruding out. Unscrew the 2 screws holding the sensor and CAREFULLY pull it out.
Unplug the wire connector. Plug in the new sensor and CAREFULLY push the wires back inside.
Replace the screws.
Turn on the oven and bake me some cookies.
Apr 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Replace temp sensor on KESC307 range
Model number is not complete and about 30 models start with "KESC307".
If you remove the two screws that hold in the sensor, Whirlpool part number 3148440, you can pull it out to cut and splice the wires together from inside the oven. Wire nuts are provided.
The part cost about $70.00.
Jan 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
775 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
