Question about GE JTP28 Electric Double Oven
Oven shuts off!!!
The top oven shuts off sporatically when it is baking. It can be on for 10, 15 or even a half hour and then just shuts of as if someone pushed the CLEAR/OFF button. No error code. Any ideas?
  • Anonymous Dec 14, 2007
    Top oven (the one most used) shuts down by itself. It usually is in the process of pre-heating. It gets near the temp then starts going backwards because it has stopped heating. It is 3 yrs old. We are no faced with a outrageous cost for a visit by repair person. Apparently, we pay for this regardless of whether the oven repair is under warranty or not. This also seem like a rip off.
  • Anonymous May 10, 2008
    I have a GE Profile convection oven that is doing the same thing.  We set the oven.  It starts but within a 5 plus minutes it shuts itself off as if the cooking cycle was cleared.  We can't cook anything because the problem is becoming a chronic condition.
SOURCE:
SOURCE: F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Posted on Mar 18, 2009
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
SOURCE: Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Posted on May 22, 2009
I have an oven that does not cook evenly. Which dial should i be cooking pastries at so i get an even cook from top to bottom
they do not recommend using all shelves at once . use middle only and rotate goods half way thru the time of the bake
Aug 02, 2017 | Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Why won't my GE P7 self cleaning oven get hot??.. When switching the oven on.. The indicator light does not come on.. but if I position it half way between off and bake ,the light comes on but no heat...
Could have a bad element in oven.or the selector switch could have a short electrically. I would shut the circuit breaker off and call an electrician to check it out.could cause electrical shock or even a fire.
May 17, 2014 | Ovens
Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Require Electronic Oven Control Guide for a drop in/slide in electric range model Model CFES365EC Frigidaire range self cleaning free standing
the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
Sep 16, 2009 | Frigidaire Ovens
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE JTP28 Electric Double Oven Logo
741 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
