Question about GE (PSS26MSRSS) Side by Side Refrigerator
Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
Even though we have the temp on the refrigerator side set at 1 it freezes food. All else seems to work - freezer side and ice maker. We can't seem to get refrigerator side to maintain a cool temp without freezing some items.
Our email - [email protected]   (in Phoenix, AZ)
  • 7 more comments
  • Anonymous Nov 09, 2007
    Problem with GE Profile Artica Refridgerator
  • djbean Dec 27, 2007
    All levels of refrigerator freeze foods, even eggs. I tried vacuuming the condensor at the back, which helped a bit, but the problem returned within a month.
  • Anonymous Jan 02, 2008
    Stuff in lower frig keeps freezing. Also ice dispenser does not work well.
  • Neva14 Jan 04, 2008
    Refrigerator side freezes on # 1 setting, isthere a solution for this problem?
  • wasupdee May 14, 2008
    I have a similar problem. milk and produce tend to freeze, Even with the setting on 1 and the freezer set on 2. I own model GSS25xGNABB. How much to fix this and can I do it myself or do I need a repair guy?
  • Anonymous Feb 03, 2009
    Similar problem here. We had a technician come out today & take a look. He said the problem is with the thermistors, and the total repair is about $400-450.
  • Anonymous Mar 18, 2014
    I freezes the food in the back of the refrigerator even on setting 1
    It freezes food in the back of the box as well as the crisper even on setting 1
  • Anonymous Mar 20, 2014
    everything is freezing even with temp moved to 46
  • 473 Answers
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Posted on Oct 11, 2007
SOURCE:
I have a amana refrigerator and its not working right I cleaned the condenser coils and checked everything now it doesnt seem to make ice
Is the freezer freezing the food rock solid? Most ice makers require the freezer to reach a certain temp before it will make ice. What is the model number of your unit?
Apr 06, 2013 | Refrigerators
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Ice cream mushy, no fan heard in freezer any more, no suction when I open the freezer door, ice-maker seems to be working -- I turned temp to highest setting -- ice droplets lining back interior wall,...
If the fans not working, replace the fan. You could have a defrost problem that causes evaporator boils to freeze over and may be obstructing fan blades. Check door seals also that they are sealing properly.
Nov 10, 2017 | GE Profile PSS26MGS Side by Side...
Refrigerator not cooling
sounds like the fan in the freezer isn't working.
Mar 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,142 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
