Question about Kitchen Ranges
Stove top burners and lower baking element not heating up
The stove top burners and the lower baking element are not warming up
    Scholar:
  • 43 Answers
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
Posted on May 11, 2009
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
May 18, 2015 | Kitchen Ranges
Neither bake nor broiler element heats. Stove top burners all heat. Any suggestions?
when elements are not working the main fault is burnt out elements
next fault is faulty switches or thermostat controls
have an electrician check it out
Apr 08, 2015 | Kitchen Ranges
My whirlpool electric stove not turning on
Make sure it is plugged in and you have power to your house.If everything is dead check your fusebox for blown fuses if you have circuit breakers reset the breaker for the stove by turning it off then back on. If the burners on the top work,but the oven won't you probably have a burned out bake element .To change this turn off power to the stove and unplug remove 2 or 3 screws holding the bake element and remove the wires to the element by loosing the screws on the terminals note sometimes bake elements plug in in this case just unplug. Reverse process to install. Reapply power and test.
Aug 06, 2014 | Whirlpool Stove / Oven / Range Electric...
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Kitchen Ranges Logo
376 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
