Question about Proscan 26LB30QD 26 in. LCD HDTV
THE VGA PORT DOESNT SEEM TO BE ACKNOWLEDGING THE COMPUTER OR VICE VERSA. ACTUALLY, IT DOES RECOGNIZE IT BUT THERE ARE NO DRIVERS FOR IT , ANYONE KNOW WHERE TO GET THEM
    President:
  • 814 Answers
You need to give more information about your set-up for help. What type of computer are you using and what operating system.What type of graphics card. All of these systems have to be compatible with the television input for you to get operation. I found this in the appendix of the owners manual on PROSCAN website. www.oncorpus.com. The customer service telephone for PROSCAN is 1-888-977-6722 The PC Screen continually appears and disappears.
Check the connection between the TV and the computer and see if the connector is locked.
􀁺 A “There is no signal “message appears.
This happens if the signal from the video card is exceeded for the maximum resolution or frequency of the TV. Try to set the
maximum resolution or frequency for the TV.
See if power save mode of the PC functions properly.(This is deactivated when any key is pressed or the mouse is moved)
􀁺 The screen looks like there is water flowing on it.
Check the connector connected to the TV.
􀁺 The screen is unclear and blurry.
Change the frequency and phase adjustment. Change the Resolution and frequency to the standard limit.
􀁺 Unstable and flickering screen.
The resolution and frequency of the PC's Graphics Card should be set within the TV's range. Check the TV menu’s current
mode and standard mode and set it up again.
􀁺 Some modes in standard mode are not working.
Check the compatibility of the video card.
If it is not working for compatible hardware, try to upgrade the driver of the graphics card
Posted on May 21, 2009
What can i do, my digitizer jr dongle is not recognized on my laptop?
Does the dongle attach to the serial port on the computer?
It may be that the software only recognizes a particular port (e/g: COM2:) and your PC's port is configured as COM1...or vice-versa.
May 03, 2014 | Sewing Machines
My graphics card is not being recognized. Im using a ECS 945P-A Ver: 3.0 motherboard which has no on board video output. im using a Zotac Technology GEforce 7300 GT graphics card too. Do I need a powe
I don't believe that graphic cards of that level need PCI-EX power directly from the power supply (using a power supply cable with a PCI-EX connector). This is a good thing, but that's because this is a low-level card--one that likely needs nVidia legacy drivers: It's likely that active driver support has ended. (The same is true for legacy AMD/ATi cards--and other more ancient cards, as well. ((PCI or AGP) Sabre, 3DFX, etc.)
If you're using the VGA port--perhaps the card's DVI port is needed for initial install, instead--or vice-versa. (You'd need an adapter or different cord to run to a VGA monitor or TV's VGA port .)
Rarely, two VGA ports might exist on a card, instead. In any case, the port needed likely isn't the one connected (with a ribbon cable) to the PCB on the video card. (Once you get a workable video card driver installed, then you should be able to use either port.) Try all usable ports before finding another possible solution....
Apr 05, 2014 | ECS 945p-a Intel 945p Socket 775 Atx Mb...
I have an AOC 22+ it is just a little over a year old (just out of warrantee) When you turn on the monitor and boot the computer the monitor will go thru its start up showing the AOC logo then it goes...
unfortunatly i believe the monitor may be dead. also check the connection on the monitor itself (the cable) some of these monitors are picky about which port is active dvi or vga there should be an option to change the input on the monitor itself from vga to dvi for the connection i hope that helps let me know!
Mar 14, 2011 | AOC V22 22" Monitor
My computer link software is not recognizing my calculator
You need to make sure you are using a USB 2.0 port. Also, many laptops tend not to recognize the calculator due to a lack of sufficient power. I have also noticed that in desktop computers, the calculator will work in the rear USB ports but not the front, or vice versa.
Jan 24, 2011 | Texas Instruments TI-Nspire Graphic...
My Windows XP Won't Acknowledge My Lexmark 6570 Printer
Try re installing the drivers for the printer that should work
Jun 18, 2009 | Lexmark X6170 All-In-One InkJet Printer
MB P21G V3.1 Cannot use USB port (with USB flash drive)
You, probably have what is quite a common problem. Your system cannot recognize the USB, because, either your USB requires a USB 2.0 input or vice versa. Most moedern MB's have either both kinds or they work with regular USB. It might take you some time, or if you the manual, it will take you no time to be up and running. Personally I like the PCCHIPS. They make a good product, they have the currency exchange on their side and here in the US, they provide us with a good and reliable product. Let me know how you make out. This is the way I get graded...
My name is Constantin
Jun 01, 2009 | PC Chips MB PCCHIPS M861G V1.6 K8M800 754...
I'm using DVI to HDMI adapter to connect MacBook with Emerson LCD TV--computer doesn't seem to recognize it and vice versa
Video card does not support the signal to the TV and vice versa hence its not a computer monitor but it will work for most PC's and some mac's
Thanks.
May 05, 2009 | Televison & Video
Vga for NEC VERSA FC160
According to the specs it's a SIS 740. Here's the support page...Look it up under C160.
Apr 27, 2009 | Toshiba Satellite 1405-S151 Notebook
PSP Troubles - unknown device
This is what you should do;
1. Restore your psp to factory setting.
2. If this does not solve the problem, then i guess you'll have to change the psp battery.
This should resolve the problem that you are facing with the psp right now.
Good Luck.
Jan 18, 2009 | Sony PlayStation Portable (PSP) Console
Usb
To use the a USB, just connect it to a computer usb port and wait for the computer to recognize and completely install drivers for it, then when the computer already recognize the USB device ou can just double click Mycomputer icon and you will see there an external drive that is the USB , double click on it and now you can already copy and paste from your computer going to the USB and vice versa........
DOn't forget to rate the solution FIXYA thank you..............
Oct 22, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Proscan 26LB30QD 26 in. LCD HDTV Logo
289 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
